battery drain
Old Mar 3, 2021 | 07:15 AM
chrisandshanescarsltd's Avatar
Default battery drain
Hi and thanks in advance for any help you can give me.
We have an 2003 X-type with a 2.5. It has developed a 300mA draw and kills a new battery over two days. We have located the draw in the instrument cluster. My concern is that, something outside the cluster is not letting it go to sleep. In connector IP10 pin 15 and 16 we have battery voltage when everything turned off. Or is it just a bad transistor in the cluster.
Old Mar 3, 2021 | 12:10 PM
Dell Gailey's Avatar
Old Mar 3, 2021 | 02:08 PM
Hi Dell
Have already read those posts and these are test we do on a regular bases. We have located the cluster as our drain (300ma) . But don't want to just go and replace it when its possible another module is not letting the cluster go to sleep.
Old Mar 3, 2021 | 04:12 PM
So you read about the slight possibility of the "stuck" CCM piston?
Old Mar 4, 2021 | 09:21 AM
Hey Dell just read through it again. CCM? climate control module?. we have located it in the instrument cluster. pulling fuse 74 reduces the draw to 21mA . thanks for your help
Old Mar 4, 2021 | 03:47 PM
Yes, a very old thread by one person said they found a sort of dirty "piston" in the climate control that was sticking open and causing the car to not go into sleep mode. Only mention I've ever seen on this.
CWheat777
Feb 25, 2020 02:22 AM
orangeblossom
Aug 17, 2018 12:30 PM
Carlos Vazquez
Apr 16, 2017 09:03 AM
draganapiazzola
Jan 16, 2015 04:49 PM
newboy
Nov 23, 2010 05:04 PM
