Battery Positive Cables Gone Bad
Old Dec 14, 2010 | 04:03 AM
mmolaik's Avatar
Default Battery Positive Cables Gone Bad
My battery positive cables have gone bad as they get hot when the car is running. I want to know if these cables are special or I can buy cables from the spares shop and replace them. The price at the dealer is way too high.
Old Dec 14, 2010 | 06:53 AM
uropnm6's Avatar
You can buy them from anywhere just make sure that they are at least the same gauge (thickness of the copper wire not the covering) In my bmw I used welding cable because I could buy it by the foot.
Old Dec 14, 2010 | 11:36 PM
mmolaik's Avatar
Thanks. I found a spares shop where I can buy the length I want and buy the battery terminals and lugs seperately. Immediately the car is started the positive terminal at the battery gets hot. The battery is new. Anyway this was happenning even before I replaced the battery.
Old Apr 4, 2012 | 06:54 PM
Nardoswiss's Avatar
Hi everyone,
Just bought a new positive cable to replace the old one, but found that there is no room at all around the alternator. I tried different wrenches, sockets ...but nothing works. What kinda a tool should I get to remove the damn 12mm nut?! I do not want to remove the fan assembly (its ridiculous). I was thinking about a flex extension but not sure it will help in this case. Any advise?
Thank you guys in advance!
Old Apr 4, 2012 | 10:45 PM
Nardoswiss's Avatar
Anyone?
Old Apr 5, 2012 | 10:19 AM
myjaghasspark's Avatar
This shouldn't be to hard to do if you lift your front end off the ground and remove the under engine tray. I could then reach the cable end from underneath. Give this a try cause thats how i did mine.
Old Apr 5, 2012 | 09:12 PM
Nardoswiss's Avatar
Thx for the tip. Tried to reach the nut from underneath but it was even more complicated, huh. Anyway, did everything from the top. It was quite a challenge, but
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
Rlover
Mar 30, 2016 10:04 PM
lordpeterk
Sep 6, 2015 01:50 PM
