Blank Navigation screen
Old Oct 24, 2014 | 03:11 AM
  #301
GKEY38rus's Avatar
нello to all
I have exactly the same problem with the monitor on my Xtype 2001 (
Check the wiring harness - all ok
checked the monitor ( diagnosis ) - all ok
checked the drive in the navigation block - all ok
checked all the fuses - all ok
downloaded Loading KWI
recorded on the DVD R + at the very minimum speed drive
complied with all the items a disc is in the drive
nothing works still (((
Old Oct 24, 2014 | 05:52 AM
  #302
costy's Avatar
hello all
i tuched the s/w button ((
i'm from Romania and i have the same problem ext 50/51.(disconecting appears C1)
my car is a x-type 2003 2.0 D.
i loaded at least 20 verbatim and sony dvd-s dl with the loader.kwi burned at 2x and nothing happen, same disk are spining alot and same less???? when is reading the disk the error is disapear please help me with another loading.kwi or other software (daniel.popescu@deltatel.ro)
in my country is not a jaguar representance
this forum is my last resurce
Old Oct 24, 2014 | 07:38 AM
  #303
GKEY38rus's Avatar
Originally Posted by costy
hello all
Hello brother in misfortune )
You've already checked the fuse box that is located in the cabin ?
Old Oct 24, 2014 | 11:21 AM
  #304
Paulc732's Avatar
hello all
how long do you wait after loading the disk?
can take up to 15 mins for the File to load.
Old Oct 24, 2014 | 11:49 AM
  #305
costy's Avatar
I waited several times 1 hour and I checked all fuses and they are OK.
Old Oct 26, 2014 | 10:13 PM
  #306
GKEY38rus's Avatar
hello
I did everything as you wrote - but nothing happened to my screen is still not working
so
I downloaded the file KWI
I recorded it on a DVD R + at 3 , then on another drive with a speed of 4
recorded as a data disc
finalize entry
put the key in the ignition , turned
Insert the CD in the drive
pulled the key wait 30 seconds or a minute
put the key in the ignition again , turned
waited up to 1 hour
but nothing happens still (
what am I doing wrong?
Old Oct 27, 2014 | 05:52 AM
  #307
Paulc732's Avatar
GKEY,
Looks like you are doing everything needed,
How did the issue start? do you have a blank screen and displaying 50-51 on you climate control .
what software are you using to burn the DVD?
have you tried copying the loading KWI from your original nav disc and burning that to a dvd?
What year is the Navigation disc you are using ?
If the Loading KWI file is not working there is a good chance that the DVD drive has gone bad but lets try a few different files first.
Old Oct 27, 2014 | 01:10 PM
  #308
GKEY38rus's Avatar
GKEY,
In order of
I have a black screen and does not work
multimedia and climate.
on the lcd temperature two errors - 50 and 51 when it .
in the DVD Navi license disk with the software or the card does not , and if he had been a time when it is lost .
Since I live where there is no Jaguar dealer and never -Extremely hard to find a solution to this problem either
For the record , I used a few programs - is ISO (free), Ashamploo Burn, Nero
Disc loading KWI I took the file that you laid out earlier.
Disc Denso navigation for Jaguar , LR , Ford 2009 I downloaded in Russian forum and recorded on DVD R + at low speed alsо
P.S. sorry for my English )
Old Oct 27, 2014 | 05:57 PM
  #309
Paulc732's Avatar
Here are the 2002 and 2008 Loading.kwi files
make sure to unzip the file open the file that you have unzipped and just burn the loading.kwi file
hoping one of these works for you.
and your English is very good
please PM me your email and i will send you the 2008 KWI file as its a little to big to upload here
File Type: zip
Old Oct 28, 2014 | 04:59 AM
  #310
GKEY38rus's Avatar
Thank you so much ! Got the files , check tomorrow . Send my Jag in a car repair service
Found in my city engineer who repairs Jaguars)He promised to fix something in the wiring.I will you accomplish your goal by the result
thanks for the help sir
Old Nov 5, 2014 | 11:23 AM
  #311
NW1996's Avatar
Hi guys I bought a donor car for my jag as I need some parts for my X-type as it worked out cheaper rather than buying all the bits from a local brakers,
anyway it has a denso sat nav(original) and its not working(blank)
I can see it flash like when you turn on tv with no input it stays black but you can see it turn on. I have tried to burn the KWI file but it did not work, the dvd unit ejects the dvd no problem.
Is there is anything more I can do to make it work??
Old Nov 5, 2014 | 05:15 PM
  #312
dennis black's Avatar
well i have had a few friends with x-types and had the same problem, how i fixed it was have them order a used dvd rom reader i installed it problem solved,
for one friend i adjusted the reader screw in side of the reader the worked also
Old Nov 6, 2014 | 12:28 PM
  #313
NW1996's Avatar
I will try again tomorrow.
Has anybody got the kwi or other files that worked for them??
If they could pm me the file.
Old Nov 6, 2014 | 02:52 PM
  #314
NW1996's Avatar
Just have tried the Audio,Nav and temp up and it showed the diagnostic menu so there is a sign of life.
Old Nov 6, 2014 | 05:08 PM
  #315
flyguychrisw's Avatar
Talking
hey guys,after buying three differant readers i found that none of them would reboot.(must of had the same problem).understand the problem is not the burner,its your computers ability to read or communicate with it,so stop pulling yours apart.you will only find there is not much you can do and anything you can do will have you diging in your pockets.just download the file to a regular cd,(not a dvd) USE A PROGRAM OTHER THEN YOUR DEFAULT WINDOWS MEDIA PLAYER TO BURN THE DISK.i did and now i have 3 nav readers working.remember its not the reader its your computers ability to communicate with it!hope this helped.
Old Nov 10, 2014 | 06:49 PM
  #316
forever76's Avatar
Default I am need the software my screen is blank and the code that is flashing is 50 51 can
Originally Posted by FactoryJaguarTech
PM me your email address. I will send you a file. You need to burn it to DVD-R loose then start car, remove map dvd and insert the one you burned. Screen should say updating. If it doesnt, just let it run for 1o minutes, then cycle ignition. I hope it works. If not you likely need DVD reader.
can i get help getting the software so my screen will work
Old Nov 13, 2014 | 03:58 PM
  #317
Akeesa's Avatar
Hi,
Pls help me I want know how download or buy software disc ? I done same thing . Now my sat nav all black . Ple help me
Old Nov 13, 2014 | 04:15 PM
  #318
Akeesa's Avatar
Originally Posted by solidx
check your email !
Hi could someone send me the s/w for my x type sat nav pls . This my email
akeesa2012@gmail.com
Thanks ...
Old Nov 13, 2014 | 04:19 PM
  #319
Akeesa's Avatar
Default Help me code 50 51 my sat nav black screen
Hi could some1 send me the s/w for my x type sat nav,pls this my email
Old Nov 14, 2014 | 12:09 AM
  #320
GKEY38rus's Avatar
Hi all again! )
Well it's been a few weeks, and I'm still at the same stage in the solution of this problem with his car .
But I do not waste time ) I changed the broken old generator and voltage regulator relay on your car (you can not even imagine what it cost me to find a home on Jaguar Parts in snowy Siberia ))).
At the moment, with the electrician in my car all right . But the problem with the idle display and control unit climate control still remains .
I downloaded the file KWI 132 mb, which kindly provided me Paulc732 But it did not help me in this matter .
