Blower Motor Replacement...
Old Sep 24, 2012 | 09:51 PM
chiefshb's Avatar
Default Blower Motor Replacement...
Forgive me if this is already explained somewhere. I did searches, but can't seem to find anything on a X-Type. I have a 3.0 that I've been told needs a new blower motor. Does anyone have an idea where this part is and what the difficulty level of this job would be. I can probable handle a 6 or 7 on a scale of 10.
Thanks in advance.
Old Sep 24, 2012 | 10:52 PM
disguay's Avatar
Download the JTIS from this site. It will help you a ton and will have step by step instructions
Old Sep 25, 2012 | 03:47 AM
Originally Posted by chiefshb
................. Does anyone have an idea where this part is and what the difficulty level of this job would be. I can probable handle a 6 or 7 on a scale of 10.............
You should recognise the Blower Motor location in relation to the vents in this drawing:
The removal and replacement instructions in JTIS are some of the briefest I've seen:
1. remove the Blower Motor lower cover
2. disconnect the electrical connector
3. remove the Blower Motor retaining screws
Of course, this doesn't guarantee you don't need to be a contortionist to get to it!
Attached Thumbnails Blower Motor Replacement...-x-type-heater-blower-motor.jpg
Old Sep 26, 2012 | 04:50 PM
chiefshb's Avatar
Thanks, guys. I tried to install JTIS last night. It runs, but there are no pictures. Will have to look at, again. I'll look this weekend to see if I can spot the blower motor...something tells me this isn't the part I need, though. The engine light is on and I was told the blower motor never would cause that. The noise I hear is coming from the engine compartment.
I have an appointment to have it looked at by a different mechanic on Friday, so we'll see what he says.
Old Sep 29, 2012 | 07:05 PM
chiefshb's Avatar
So I took my car to another mechanic and they told me what I thought was the actual issue. I need a radiator cooling fan motor...not a blower motor. So now here is my question to the forum crowd...do I replace the motor in question or do I go ahead and replace the entire fan assy? I found this one on Ebay and they have over 680k positive feedbacks with a 99.9% rep, so I'm not concerned with getting a bum part. My only question is should I just go ahead and replace it all since I'm there? Who knows how long until the other motor may give, right?
What to you think?
http://www.ebay.com/itm/02-06-Jaguar...667d2e&vxp=mtr
Old Sep 30, 2012 | 07:43 AM
Thermo's Avatar
Veteran: Navy
chiefshb, I am not questioning the shop, but why do they think it is the fan motor? I know you mentioned a noise in the engine bay, so, that may be the answer. But, from our experience the fans hardly ever fail and the control module for the fans is what fails 99% of the time. If the fan sounds like it is going to blow up, then yes, the fan is bad. But, if the fan simply is not turning fast enough or not turning at all, then I would be looking at the control module first.
One other thing I would inquire about is ask them if the fan shroud has the new or old style plugs on the fans. In 2004 Jaguar switched the plugs because they used a new style fan controller. So, there are 2 different style plugs out there for the fans. I can not get the link to come up, but you can probably ask them what year vehicle it come out of and then go from there.
Old Sep 30, 2012 | 10:37 AM
chiefshb's Avatar
It's making a ticking/squealing sound when it runs. He said it didn't need to be changed out just yet, but if I want to do other things to the X or my truck, I've been instructed it will be fixed (fiance's orders).
I'll find out about the plugs. Thanks for the heads up.
Newark Nj Gang
Oct 2, 2015 02:39 PM
inactualis
Oct 2, 2015 11:13 AM
davidboger
Oct 1, 2015 10:13 AM
JagBrian
Oct 1, 2015 12:52 AM
