Body question
Old Nov 24, 2013 | 11:10 AM
Erikcue's Avatar
Default Body question
Hello all,
New member here. I have a 2002 xtype 3.0 sport, and have little mechanical knowledge. The attached image is of a cap that broke from the front of the car near the headlights. Please can someone tell me what it is? What it does? And if its easily replaceable.
Thanks!
Old Nov 24, 2013 | 04:09 PM
Alfadude's Avatar
That's for the headlight washers. I don't think it is hard to replace. Do a search on here. I know it has been talked about in the past. I don't have that on my car, so have no experience with it.
Old Nov 24, 2013 | 07:58 PM
Jac's Avatar
Jac
Originally Posted by Erikcue
Hello all,
Thanks!
This is what you need. You might also want to get the pivot mounting swivel too. They are made of metal instead of plastic (like the factory ones).New Jaguar x Type Right Headlight Washer Jet Covers C2S30310XXX | eBay
Old Nov 24, 2013 | 10:01 PM
Erikcue's Avatar
Default re:
Thank you for the quick help! I got it ordered.
Old Nov 25, 2013 | 12:16 AM
disguay's Avatar
So I ordered this, tried to connect it to the washer jet, and couldn't get it to work for the life of me. So, I removed the clip and just epoxied that sucker onto it.
Old Nov 26, 2013 | 06:51 PM
Erikcue's Avatar
Default Epoxy
I had actually found it when it broke and superglued it back on. Gorilla glue brand did not last and it broke off again while driving somewhere. I learned my lesson and if I cant mount them I'll use epoxy for sure.
Any tips on how you applied the glue?
Thanks again
Old Dec 1, 2013 | 09:46 PM
Fezz's Avatar
I did the 5 minute epoxy myself as well, but it eventually wore due to the weather and I lost the washer. You can buy headlamp washers alone, the clip alone (there are aluminium ones manufactured) and ones that are fibreglass with the clip attached to it. I recommend getting the fibreglass washer, and replace the plastic clip on your other washer with the aluminium clip.
bamforp
Aug 14, 2024 05:36 PM
tbird6
Aug 13, 2024 07:50 PM
way2far
Aug 31, 2022 09:26 AM
Gus
Oct 15, 2019 12:29 PM
