Brake guide pins
Old Jun 23, 2016 | 06:11 PM
swingwing's Avatar
Default Brake guide pins
Am replacing front pads and rotors on my 2004. I took the guide pins out of the caliper bracket for cleaning and noticed that one of them has a rubber sleeve on the end. Does it matter which hole this pin goes back in?
Old Jun 24, 2016 | 03:54 AM
faltwen's Avatar
I've just done all 4 brakes on my 2008 version and it's the 1st time they've been done. The calipers are the same as the earlier model and I found that the pin with rubber on was in the bottom on the front calipers but in the top on the rear calipers. I don't k now why they are different, probably something to do with the front calipers being in front of the disc and the rear vice versa?
Old Jun 24, 2016 | 05:02 AM
iownme's Avatar
Yes it does need to go back the same way.
If incorrect lubricant is used the rubber will swell and the calipers will barely move.
Use a synthetic, rubber friendly grease.
As you noticed, the front is different to the rear, keep them that way
Old Jun 24, 2016 | 06:23 PM
Paulc732's Avatar
The best thing to use on the pins is silicone paste.
Amazon Product Link
Old Jun 24, 2016 | 07:16 PM
swingwing's Avatar
Used CRC Brake and Caliper Grease. Bought rotors and Akebono ceramic pads from RockAuto. There's good YouTube videos put up by English company called Autodoc. Brakes went together nicely; now just waiting on a replacement rear shock bolt to get car off blocks and back in service. Sorry for wrong picture orientation - took with my phone and don't know how to reorient them.
Attached Thumbnails Brake guide pins-fronts.jpg   Brake guide pins-fronts1.jpg
2010XFR
Nov 28, 2016 05:39 PM
WhiteJag
Apr 5, 2016 03:22 PM
scottpeterd
Apr 4, 2016 10:48 PM
daves_ale
Apr 3, 2016 07:46 PM
dartech
Apr 2, 2016 06:28 AM
