a/c compressor not working?? not cold air
Old Aug 15, 2010 | 06:30 PM
maikal_0011's Avatar
Default a/c compressor not working?? not cold air
hi
i was going to post the same question in another thread but looks like it kind of ended.
so my question is what are the failures of compressor failure?
cause air doesn't get colder until i give lots of gas. i got it checked out at two local shops and they both said my compressor is working but not doing its job properly even though low pressure side was around 40is and high was around 250is, which according to my knowledge are normal, aren't they?
so i was going to go ahead and add some freon, but i don't want to waste 30-50 dollar on freon if have to replace a compressor
any ideas?
Old Aug 15, 2010 | 11:27 PM
Topdawg82's Avatar
Your pressures look good. Check to make sure that your recirculation door is not stuck in the fresh air position. I found that on the X-types the only way to get the a/c good and cold is to use recirculation, but many times the door is stuck in fresh air and it will never get all that cold.
Old Aug 16, 2010 | 12:43 AM
i am newbie so i don't how to check for recirculation door, can u guide me right direction?
but i don't understand, my car is stick shift and when i am in neutral gear and just press gas padle and rpm goes to 4000 and up then it gets descent amount of cold but not really cold, so if that door is stuck then it should never get colder no matter if i press gas padle or not.. OR i don't understand recirculation door concept..
just for the info: fan is working in descent speed, and heating seems to be in fine.
and just quick question: do u need compressor for heating? because if yes then my compressor is not the problem and vice versa.
Old Aug 16, 2010 | 05:40 AM
Jagtec1's Avatar
Press the recirc button and listen for an audible change in the fan speed/sound. If there is no change in the way it sounds, then the servo is spinning, but the flap is not moving. Compressor is not used for heat.
Old Aug 16, 2010 | 09:45 PM
yes it does change speed/sound everytime i turn on/off circu button
just give u guys more details i made video about this, so please check it out and see what do u guys think..
thanks in advance
http://www.youtube.com/watch?v=AyEla7oKb5o
BrentGardner
29
Dec 16, 2024 12:13 AM
Xj812
Oct 26, 2015 05:04 AM
johanasu
Sep 3, 2015 12:39 PM
mikebaker3
Aug 31, 2015 10:44 AM
casepie
Aug 30, 2015 09:49 PM
