A/C not cold
Old Mar 14, 2012 | 11:33 AM
MosDefXType's Avatar
Default A/C not cold
so the temps are kinda high and i decided to turn to a/c, it's not cold. fans are working and i had belts changed recently...could it be the a/c "gas". help i have a feeling this summer is going to be boiling hot.
Old Mar 15, 2012 | 03:17 PM
MeeMo's Avatar
as much as i love the x-type i have to say that the a/c compressor is really bad in this car
i had to chage mine every year :S
Old Mar 15, 2012 | 03:26 PM
Take a look at these
File Type: pdf
File Type: pdf
Old Mar 15, 2012 | 04:13 PM
blaydes99's Avatar
Norri, if I'm reading JTB00183NAS1 correctly, it's possible to flip that AC valve without removing the compressor? Just evacuate system, flip valve, reseal, and recharge system?
Old Mar 15, 2012 | 04:51 PM
Yes.
As long as you have access.
Old Mar 15, 2012 | 08:02 PM
joycesjag's Avatar
Wish I would have tried this before replacing the compressor on our S Type!
https://www.jaguarforums.com/forum/a...D-ac-valve-pdf
Old Mar 17, 2012 | 07:47 PM
JagXster's Avatar
ok, I'm daft here.
From what I m reading, you remove the valve, then the spring comes out. Now they want me to put the valve in first & the spring on the outside??? then the cover?
Old Mar 22, 2012 | 01:25 PM
Paul Z's Avatar
It is not a misprint in the bulletin? You remove the spring from under the valve and put it on top of the valve? Has anyone done this or had it done and it works? Is it a manufacturing error in the first place?
Old Mar 22, 2012 | 01:28 PM
Paul Z's Avatar
Originally Posted by JagXster
ok, I'm daft here.
Did you ever get an answer?
Is it a misprint in the bulletin? You remove the spring from the underside of the valve and put it on the topside of the valve? Has anyone done this or had it done and it works? Is it a manufacturing error in the first place?
Old Mar 23, 2012 | 01:41 PM
JagXster's Avatar
NO answer yet
redxk8
Oct 4, 2015 08:28 AM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
42Ajd
Sep 26, 2015 07:04 PM
