can you start the x type with the Climate Control removed
Old Nov 6, 2019 | 12:54 AM
JagQ's Avatar
Default can you start the x type with the Climate Control removed
Hello guys.
I need to remove the climate control unit from the car, "need" here is for "want" in order to replace the LCD, however it is my daily car now.
so is there a way i can make it start and run with this unit out ?
Thank you
Old Nov 10, 2019 | 01:47 PM
edtoo's Avatar
I don't think so, the climate control units are part of a system management loop. Taking it (or several other components) out breaks the loop and then the car won't start.
Old Nov 10, 2019 | 04:27 PM
astromorg's Avatar
This is the CAN Bus layout. You can see that the Climate Control Module is in the run between the ECU and the Instrument Panel etc! so removing it will disconnect an essential link. Bearing in mind that the transmission Module and the Selector module are omitted in manual cars, it may be (I take no responsibility for your trying!) that jumper links for the Yellow and Green CAN wires will work. Note the wires should be twisted together as per the existing circuit.
Old Nov 13, 2019 | 12:26 AM
JagQ's Avatar
Thanks for the reply.
I will try to get a spare one before i attempt doing this,,,,,
I still remember when i took it out the first time to replace the LEDs with white ones, turned out to be a huge job so instead of replacing them i simply added a white strip on top of the LCD
but when i tried to start the car it gave me all kinds of errors and it was some scary time before i realized (thanks to this forum) that i had to put it back to get the car running.
Old Nov 13, 2019 | 02:05 PM
edtoo's Avatar
Where are you located JagQ? I've got a spare climate control unit.
Old Nov 13, 2019 | 03:49 PM
Dell Gailey's Avatar
@edtoo = says he lives in San Marino. You can see country of residence by looking at their member profile.
Old Nov 14, 2019 | 09:56 AM
JagQ's Avatar
Thanks for your offer, found one on ebay for GBP 14.90, should get it shortly.
srjag
Oct 22, 2023 08:29 AM
310jag
Apr 8, 2019 03:12 PM
1927
May 20, 2018 11:18 AM
Dirk Bailey
22
Jan 27, 2013 07:22 AM
Glendoramike
Sep 24, 2011 05:23 PM
