Car audio volume
Old Jul 31, 2009 | 07:53 AM
digimurda's Avatar
Default Car audio volume
Hi,
i got a 2002 jaguar x-type with the factory regular audio system.
My problem is that when i turn the volume up loud after a few second it dims its self down automaticly.
The volume level (numbers) stays the same.
Lets say i have it on max (35) , it will stay on 35 but it will dim a little.
Can i bypass this???
Help..............
Old Jul 31, 2009 | 08:20 AM
Greenhornet's Avatar
Default volume
Check your setup screen, see if you have the auto volume set.
Old Jul 31, 2009 | 08:27 AM
digimurda's Avatar
how do i do that?
Old Jul 31, 2009 | 08:43 AM
Default volume
I have the Nav on mine and on the right side (buttons) there is a Menu button, once you press that you go to a screen that has set up, volume preset etc. If you don't have the Nav setup then i'm not sure how you would access that menu.
Old Jul 31, 2009 | 08:51 AM
digimurda's Avatar
yeah i dont have the nav.
Old Jul 31, 2009 | 09:04 AM
I was looking for some close up pics of that setup up but can't find any with close enough detail. On your radio the buttons that allow you to tune stations and set clock and other stuff???
Old Jul 31, 2009 | 09:26 AM
Default buttons
Saw a closeup pic, what does that MR button do and those two telephone buttons (2??).
Old Jul 31, 2009 | 08:32 PM
ajl1212's Avatar
It's been a while since I've messed with the audio system on the X-Type but I think the Auto Volume Control settings can be changed by pressing and holding the 'mode' button (next to the volume knob). Once you hold for a while (3 seconds or so) a new menu should pop up. If you press the mode button again, it should scroll through different options/settings. Like I said, it's been a while but I think that's how it's done. Let me know what happens....
Old Jul 31, 2009 | 10:47 PM
kandA's Avatar
@ Greenhornet: The MR and the phone buttons are for when you have a phone hooked up directly to the car's audio system. Unfortunately, the only phone hookup they ever had for this car was some old Erickson phone, so those buttons are obsolete.
@digimurda: I have the same audio system and I have gone though all of those menu's. I wish I could help you, but I have never found an auto volume control on mine. Try the menu you get to by holding the mode buton, if it's anywhere, it would be in there.
rvdz
Dec 7, 2019 06:42 AM
jdzubas
Oct 4, 2015 09:14 AM
Jandreu
Aug 29, 2015 07:31 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
