center bolts on valve cover
Old Oct 13, 2012 | 05:37 PM
leaperjag's Avatar
Default center bolts on valve cover
Im trying to find the center bolts for the valve cover. I need to order one but cant find them. any help is appreciated.
Old Oct 14, 2012 | 08:06 PM
Thermo's Avatar
Veteran: Navy
leaperjag, if you can get the bolt out, take a run over to Fastenal and see what they can do for you. May not be the cheapest route, but you will get the right part. The other possibility is to take a run through a junkyard and see what you can find there. Should be able to scavenge off of a Lincoln LS with the 3.0L motor.
Old Oct 18, 2012 | 04:40 PM
leaperjag's Avatar
Thanks Thermo, Do you think the 2.5 motor has the same bolt? could I get one from the dealership maybe?
Old Oct 18, 2012 | 06:28 PM
Thermo's Avatar
Veteran: Navy
leaperjag, yes, the 2.5L motor uses the same bolts. So, if you can get bolts from that, then go for it.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
jaggermang
Sep 8, 2015 07:07 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
