central lock problem
Old Apr 19, 2017 | 02:40 AM
eurocare's Avatar
Default central lock problem
what causing the problem on my x type, i cannot open the central locking from inside, i have to remove the key from the ignition switch and press the unlock button for me to open the door.
Old Apr 19, 2017 | 09:56 PM
avern1's Avatar
Does it only do it on one door or all doors. If only one door won't open the lock it could be a stiff rod. I would recommend getting a good spray silicone lubricant and spray the lock mechanisms and exercise the door handles. It might be a quick fix then again it might not.
Old Apr 20, 2017 | 02:23 AM
eurocare's Avatar
yes! i cannot open all doors from inside also from the outside. i need to pull out the key from the ignition switch and press the unlock button.
Old Apr 20, 2017 | 08:21 AM
DaveJessop's Avatar
I have the same problem with all doors
Old Apr 20, 2017 | 09:54 AM
avern1's Avatar
Can the doors be unlocked using the key from the outside of the car? The question is for both of you. Also, have you tried lubricating the mechanism?
Old Apr 20, 2017 | 10:32 AM
DaveJessop's Avatar
No problems unlocking all the doors from the outside - both times it has happened to me was when a passenger got out and then tried to get back in a couple of minutes later with the engine off and me sitting in the drivers seat - could not open my door when she tried to get in either so had to use the fob
Lubricating is an idea but both doors locking at the same time is a bit of a long shot and I put it down to a fault in the auto lock thing where all the doors lock when you are moving or the central locking chip
Old Apr 20, 2017 | 07:32 PM
eurocare's Avatar
Yes,it works perfectly fine. i can lock and unlocked it from the outside using the key pob.
Old Oct 10, 2017 | 04:37 PM
Jim Hadley's Avatar
Hi, I had central locking problem with my 06 X type until someone suggested it may be a problem with a pin in the ignition switch sticking. After many weeks of trying difference things I sprayed WD 40 into the ignition, worked the key a little and was amazed it done the trick. I hope this might help someone with the same problem.
rickead2000
Nov 28, 2018 12:42 PM
Jeff DeVere
Oct 13, 2016 07:00 AM
95Leaper
Oct 9, 2016 07:06 PM
Oct 25, 2009 03:21 AM
Jul 23, 2005 12:07 PM
