Central Locking
Old Jan 25, 2025 | 01:59 PM
skyline.za's Avatar
Default Central Locking
Good evening,
Let me begin by saying that I'm glad to be here. Jaguar's a lovey car for the ones that can appreciate it.
Had a 1986 XJ6 back in the day but sold it long time ago and I recently purchased a 2003 X Type the 2 litre one. Very nice car. Gave me a very hard time with the fuel pump but got around that and it works just fine now.
The issue that I'm facing now is with the central locking. Co drivers door will not lock or unlock with the remote control. If I lock it from the inside it locks all doors !!!
My knowledge is a bit limited on the Jaguars so if anyone's some advice for me, it would be appreciated .
Christos
Old Jan 25, 2025 | 04:35 PM
Peter_of_Australia's Avatar
I hazard a guess:
Since locking the passenger door from the inside locks all the other doors, it does not sound like an electrical issue.
Thus, it would have to be a mechanical issue on the passenger door module (i.e. the passenger door lock).
This is sadly quite common.
Here s how I fixed my problem (my Jag is a RHD):
https://www.jaguarforums.com/forum/x...-lock-271041/#
If this does not help, try to find a replacement lock.
Old Jan 25, 2025 | 05:12 PM
dh53's Avatar
Does the remote control work at all? Could it be simply that the remote needs to be paired to the car?
Old Jan 26, 2025 | 07:39 AM
The way I understood "skyline" was that the remote locks and opens all other door except for the passenger door.
Thus, if I understood that correctly, it can't be a remote-pairing-issue nor a remote-battery-issue...
Old Jan 27, 2025 | 03:55 AM
skyline.za's Avatar
Hi thank you,
Yes it does it locks/ unlocks all other doors .
Just co driver's door doesn't respond. Manually it works fine.
Old Jan 27, 2025 | 04:56 AM
I had the same issue, which I why I wrote my post above (the very next post on top right after your initial question).
Old Jan 27, 2025 | 07:21 AM
Jo van Haag's Avatar
We had the same problem on several X-Types. As Peter_of_Australia already wrote, it's a mechanical problem. There were different faults. Either the lock was replaced or broken parts were replaced or repaired. If the fault only occurred occasionally, it was the microswitch fitted to the lock.
Old Jan 27, 2025 | 01:54 PM
Yes, that microswitch is the issue. However, more likely not the microswitch itself, but the mechanical triggering of that microswitch does not work anymore due to broken parts (plastic!).
Bill Mac
Jun 8, 2025 02:53 PM
Clackavosticus
Feb 22, 2025 06:35 AM
Js2022
Jun 12, 2022 11:05 PM
MJG
Dec 8, 2012 04:07 PM
rids
Jul 22, 2012 03:04 PM
