Central Locking
Old Nov 15, 2007 | 12:06 PM
Cadillac's Avatar
Default RE: Central Locking
I have read that keyfobs are really problematic especially on the earlier models .I think your problem is a typcial example of them
Old Nov 17, 2007 | 08:05 PM
aquill1's Avatar
Yeah take both fobs to your local dealer there was recall on them and they either reprogram or replace them, they had to for me...but they must have both to do it...if that doesn't work also keep in mind that the door on the ignition that the key pushes needs to be closed whenever you pull your key out to lock the doors, otherwise your car still thinks your keys are in the ignition, you can lube that up if its sticking...doubt its your problem more than likely just need to be fixed by a dealer, they also shouldn't charge you for it as its a known problem...good luck
Old Nov 29, 2007 | 01:30 PM
aquill1's Avatar
If you happen to find a day where your going by your dealer stop in and have em take a look...relating to a tsb problem or recall problem they don't charge you for that...
Old Nov 29, 2007 | 07:12 PM
andersen06's Avatar
Have you tried reprogramming your FOB's???
http://www.playahsparadise.com/FOBReprogram.pdf
jluckcuck
Nov 6, 2015 07:49 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
millertic
Sep 30, 2015 08:11 PM
Bigvettefreak
Sep 28, 2015 03:03 AM
