central locking ecu location
Old May 26, 2015 | 07:47 AM
papadigz's Avatar
Default central locking ecu location
I have a central locking problem, the keys have been checked and found to be ok.I wonder if it may be the central locking ecu, they are quite cheap on ebay but I dont know where it is fitted on the car and if it needs to be coded.can anyone help
my car is an x type 2.0d 2003
Old May 26, 2015 | 01:23 PM
astromorg's Avatar
I don't know what you're looking at on Ebay, but the X Type doesn't have a dedicated security module; it's built into the General Electronics Module (GEM) that controls a whole heap of other functions as well. Perhaps if you post the details of your problem, members here will be able to help?
Old May 26, 2015 | 05:49 PM
CyJag's Avatar
Check the simple things first.
My 2006 was doing not unlocking itself when you get out, except for the driver door. Similar with the key fob- would open driver, but double-tap for all 4 doors would not work.
Turned out to be a sticky door latch. Spray some silicone lube on it and open/close a few times. Takes 60 seconds, and not a bad thing to do anyway. Try that first no matter what probs you are having, would be my $0.02.
Old May 27, 2015 | 05:25 AM
papadigz's Avatar
What actually happens is the car used to unlock with the key fob but now it doesn't,
I have new batteries in tbe keyfobs but I get no beep when trying to recode them.
the car locks and unlocks with the key but not by using the buttons.
Old Nov 21, 2018 | 08:28 AM
James Plumb's Avatar
Did you ever find a solution to this problem?
aholbro1
Dec 29, 2024 06:46 PM
BadKat174
May 26, 2023 12:29 AM
Bcrary3
Sep 12, 2021 05:41 AM
Charlene n John
Sep 14, 2015 12:01 AM
explorer364
Sep 11, 2015 05:44 PM
