Central Locking Help !!
Old Jun 10, 2015 | 12:40 PM
BradsJag's Avatar
Default Central Locking Help !!
I've just re-installed the drivers door card after replacing the drivers ext mirror.
Since then, the central locking system has not worked properly.
I assume I got the position of the internal handle wrong when re-fitting the door card. Now the locking appears to be 'confused'.
I tried to re-set the system by removing the battery leads and connecting together but without any change.
Would I need to take the door card off again, re-position the handle with the battery disconnected and then re-assemble?
Any help would be greatly appreciated.
Old Jun 11, 2015 | 07:15 AM
BradsJag's Avatar
End of Panic !!
Simply sorted ..... I didn't install the handle cable properly. The outer cable with a red plastic end wasn't seated into the bracket.
Everything back to normal now and the central locking is now no longer 'confused'.
jluckcuck
Nov 6, 2015 07:49 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
millertic
Sep 30, 2015 08:11 PM
Bigvettefreak
Sep 28, 2015 03:03 AM
