Cheapest Place For Coolant Reservoir Tank?
Old Nov 28, 2011 | 04:24 PM
funkdoktor's Avatar
Default Cheapest Place For Coolant Reservoir Tank?
After replacing my upper radiator hose assembly 2 days ago my reservoir tank decided to crap out on me today. The top nipple outlet broke off into the hose causing coolant to leak out. Is there a temporary fix? As this is my only vehicle.
Also, what trustworthy website can I go to for the most affordable tank? Dealership here in Hawaii is almost $223 before tax. I think thats crazy for a tank that will most likely break again.
Thank you & Mahalo.
Old Nov 28, 2011 | 05:03 PM
Brutal's Avatar
WELL I HAVE A USED(BUT 5 MONTH OLD) 1 IVE BEEN SAVING IN THE GARAGE FOR $50 PLUS WHATEVER SHIPPING IS TO HAWAII. OR JUST BUY ME TICKET AND ILL PERSONALLY DELIVER AND INSTALL IT
Old Nov 28, 2011 | 05:04 PM
Brutal's Avatar
Oh and your temp fix is vise grips
Old Nov 28, 2011 | 05:45 PM
funkdoktor's Avatar
I wish I had money like that. If I did I'd just go to the dealership! Hahaha
Can u send picture messages? Private Message me your # and I'll text you mines. I'm interested in seeing pictures of your spare tank. Thank you replying!
Old Nov 28, 2011 | 05:55 PM
Brutal's Avatar
Itll be awhile, im just getting off and have to go shopping with my daughter
Old Nov 28, 2011 | 06:01 PM
funkdoktor's Avatar
Cool just message me your number in the mean time. And I'll text u mines back.
Old Nov 28, 2011 | 07:07 PM
queensnewbie's Avatar
http://www.ebay.com/itm/Jaguar-X-Typ...item35b6f1d553
Old Nov 28, 2011 | 08:08 PM
funkdoktor's Avatar
i seen this. sadly it says that the seller does not ship to hawaii. bummer.
Old Dec 6, 2011 | 02:02 AM
funkdoktor's Avatar
thanks everyone. decided to bite the bullet and purchase from the dealership. did a full flush and refill at a local shop that a friend of mines works at. fingers crossed. hope my cooling system holds up.
Old Dec 11, 2011 | 09:03 PM
cujet's Avatar
Just an FYI,
I just purchased the $99 tank at the link above. It seems well made, however, mine was damaged in shipping. The small hose barb was broken off (the very same one that broke on my old tank)
I threaded the hole with a 1/8-28 pipe tap and threaded in a brass hose barb.
It's working great.
Old Dec 13, 2011 | 12:50 AM
billbjork's Avatar
2.5 X TYPE remember to turn the clamp ears DOWN if you used the OEM clamp that is what caused it to break, it hits on the underlining of the hood and the pressure causes it to fail (time and high heat help) Warranty replaced mine $100.00, ridiculous, tank is less than a gallon,I bought a 13 gal plastic gas tank for $150.00 shipped.
Old Dec 13, 2011 | 01:29 AM
funkdoktor's Avatar
thank you for the tip. I'll double check & make sure its done properly.
Wahooesprit
Dec 23, 2019 02:01 PM
willtoliv
Oct 2, 2015 12:18 PM
KarimPA
Sep 12, 2015 08:15 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
