Check engine
Old Dec 4, 2006 | 05:41 PM
andersen06's Avatar
Default RE: Check engine
I seem to have a similar issue. My dealer said it was a "soft code" which means when you turn the vehicle on, your computer does a self check and if all is well it turns the light out. If it isnt going into limp mode then its probably nothing serious. Just have the dealer run a diagnostics, Im having mine done next week.
Could be a sensor that feezes, or sticks when its cold??
Old Dec 5, 2006 | 10:08 AM
andersen06's Avatar
This is from another post, swiped from Racerx82:
Climate Considerations
Owner's manuals and service manuals will specify the acceptable oil to use at various temperatures. In warm climates, 10W30 is usually an acceptable alternative to the preferred 5W30 and may be used without measurable adverse effects. In the olden days, before multi-weight oils, it was common to have a winter oil and a summer oil. This is no longer necessary, but if you normally use 10W30 because you live in a warm climate then be sure to switch to 5W30 if you plan on using the vehicle in very cold weather.
5W30 versus 10W30
Virtually all new passenger vehicles sold in the U.S. use either 5W30 or 10W30 oil. The difference between the two is that the 5W30 flows better when cold, so if you live in a cold climate or operate your vehicle in a cold climate during the winter months, you should use 5W30 if it is the preferred oil for your vehicle. If you live in a sub-tropical climate and don't operate your vehicle in cold climates, then 10W30 is acceptable as long as the manufacturer specifies that it is permissible to use it.
Is there a disadvantage to using an oil that flows better when cold, i.e. 5W30 versus 10W30?
Sometimes, but usually not. The crux of the issue is this: the bigger the difference between the cold oil viscosity and the hot oil viscosity, the more the volume of viscosity modifiers and the less the volume of base stock. If you are good about following the manufacturer's recommended oil change interval then stick with the 5W30 if that is the preferred oil for your vehicle, even if 10W30 is acceptable in warmer climates. Older cars may specify 10W30 only. This is because they need a little more viscosity when cold to keep a protective film on the cylinder walls. There have been instances where the larger amount of viscosity modifiers that are present in 5W30 have broken down due to excessive heat and have left carbon deposits on the valves, but this is extremely rare. The proper fix would be to reduce the excessive heat, but the workaround was to use an oil with less viscosity modifiers.
Why do many oil change places, even dealerships, use 10W30 instead of 5W30, even when 5W30 is preferred?
According to www.cartalk.com (see link in the references section), as well as many mechanics who have posted on usenet, 10W30 is the closest thing to a one size fits all oil. Many older vehicles need 10W30, and most newer vehicles are okay with it in warmer climates. Since many garages don't want to have multiple tanks of bulk oil they choose to carry only 10W30. The advice that Tom & Ray give is correct, 'it would not be a disaster if you used 10W30, but given a choice, go with the manufacturer's recommendation and use the 5W30.
Old Dec 12, 2006 | 02:24 AM
Supralative's Avatar
been having the same issue here recently
last time was just this past friday
it lasted thru till Sunday though
the first time it happened it stayed on for almost a whole week
cold weather both times also
Old Dec 12, 2006 | 12:10 PM
andersen06's Avatar
Just got done with the dealer. It was a Coolant Temp Sensor going bad. Only cost $80 with labor. I was getting a high engine temp code, and it would just peg the temp gauge into the red...should be fixed now!!
Old Dec 16, 2006 | 02:48 AM
racerx82's Avatar
not bad....
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
scottatl
Sep 4, 2015 08:08 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
