Check engine light
Guest
Posts: n/a
I tried the test method for the codes and couldn't find anything related to the OBDII. I had a good number of codes after the bulb check but didn't notice any fault codes or anything that would say a fault.
The engine light came on after sitting in a heated garage for about 4 days without being driven then going out into cold weather (around 40 degrees F). Would it be a change in the temperature that set off the light?
Would doubt it as X Types were extensively tested pre-launch around the world including desert roads in Arizona and the well below freezing temps of Timmins in Canada for months and months.
BrentGardner
29
Dec 16, 2024 12:13 AM
