Check engine LIGHT
Well today one of my fuse for my headlight went out and changed the fuse. When I changed the fuse the headlight and then when I started the car, the check engine light came on. Any ideas, no none of the other fuses are burnt out as I have already checked. Any ideas.
I can't see the connection..theSES lightis mostly associated with engine emissions systems...
Maybe one of the experts here will have an example like your's to go by..
Good luck..
I'll make a guess and say it's an O2 sensor issue...
Good luck..
Im just guessing it is check engine lightjust got stuck, im going to a local shop and see it. Im not going to no dealership charging me $100 just to diagnostic lol. Its nothing major and I know that, engine still runs strong etc its just the light.
Jason if you don't want to get raped go to a local autozone or autoparts store that will allow you to check your own codes with the obdII tester...if you have an autozone they will check it for you for free! I don't know what there is for you to mess up though as the hid swap is pretty much as easy of a swap as you could do...
BrentGardner
29
Dec 16, 2024 12:13 AM
