check engine reset?
Had EVAP system checked for sealing integrity. They found leaking behind the tank so purge solenoid was replaced. Two months later check engine light back on. Could it be bad gas if so is their a reset?
It could be a different problem. You need to get the codes read again and see what it is.
In general, you need a code scanner to reset the engine light. But if the problem is not fixed/still there it will come back on. Sometimes the light will go out buy itself IF the fault that caused it to come on does not happen agian after a number of driving cycles. The code will still remain in the engine computer but the light will go out. Also, dsiconnecting the battery does nothing to clear codes so don't bother trying it.
Many Auto parts stores will read your codes for free so start there.
KarimPA
Sep 3, 2015 07:32 PM
