cloudy headlights
Old Sep 30, 2014 | 09:22 PM
kajunkooker's Avatar
Default cloudy headlights
I need new headlights. I am having trouble with my lamps on my 2006 X Type Jag. They seem to be very cloudy. I find it very hard to see at night with them I know they would be pretty expensive through the dealer, right? Any suggestions?
Old Sep 30, 2014 | 10:24 PM
clyons's Avatar
Before you buy new lamps check out these posts.
https://www.jaguarforums.com/forum/x...t-remedy-2281/
https://www.jaguarforums.com/forum/x...ctures-113809/
Old Oct 1, 2014 | 02:47 AM
SteveSheldon's Avatar
You can buy a kit, or just use anything from t-cut (a paint cutting compound for removing scratches in paintwork) through to toothpaste according to some.. The top layer of the plastic on the headlamps turns cloudy over time due to the sun.. so you remove the top layer with a very mild abrasive compound, and then seal it with a good quality wax. If you do this on a regular basis maybe every 4 or 5 months you'll be able to keep them clear and looking like new :-)
Old Oct 1, 2014 | 04:50 AM
Originally Posted by clyons
As above 2 comments really, an easy and quick fix is available and does not need to be expensive!
Old Oct 1, 2014 | 06:13 AM
Five Speed's Avatar
I used " Astonish " slightly abrasive kitchen cleaner & a wooly bonnet buffer on my rerchargeable electric drill .
Old Oct 1, 2014 | 07:21 AM
I should do that - sigh - I just struggle doing it manually whenever t-cutting and then complain about friction burns on my thumb lol
Old Oct 1, 2014 | 10:30 PM
dwclapp's Avatar
I had good luck with a Gator brand headlight restoring kit. It takes time to get good results, but like anything, the more effort you put in, the more you get out.
Lowes has it for $20:
Gator Headlight Restoration Kit
Old Oct 7, 2014 | 11:35 PM
Johnde's Avatar
I used Off insect repellent , spray and scrub, worked well.
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
sdelliott58
Sep 28, 2015 11:21 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
