cluster not working
Old May 9, 2013 | 02:59 PM
alZR1's Avatar
Default cluster not working
I had this problem for A while now.I finally bought A used cluster only to find
out that it has to be programmed to the car.I called my friend that works on european cars and nothing he says Dealer.
Well knowing that this is A Ford,I called Ford and talked to service about it,strike two.
I tried to swap out the circuit boards thinking that it might fix it.still nothing
so I took A closer look at the circuit board with loupe and found this surface mount device(SMD) off to one side as if it were de-soldered.
I soldered it and bingo everything works.
So I hope it helps some of you if not all of you with this problem.
AL.
Old May 9, 2013 | 05:16 PM
Welcome to the forum alZR1,
I've moved your post from General Tech Help section to the X-Type section.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
Forcedair1
Sep 8, 2025 01:57 PM
Bcrary3
Sep 12, 2021 05:41 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
philwarner
Sep 5, 2015 10:05 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
