Code 1643 solved
Old Aug 17, 2023 | 01:29 PM
mike in iowa's Avatar
Default Code 1643 solved
Had a 1643 thrown in the rain the other day....TCM fault, thanks to you all I was able to find out how to fix, I pulled the scuttle cover and wipers, replaced the cab filter (old one may be the oe from the factory) as I can no longer slide under the dash and figured it was a water leak opened the windows and hatch to dry out the inside...Just checked and after removing code took it for a short run...all is good...thanks for the help
Old Aug 17, 2023 | 03:02 PM
motorcarman's Avatar
Info we got when these cars were in NEW CAR WARRANTY.
Old Aug 18, 2023 | 10:56 AM
Thank you for the info...I think the water proof seal idea maybe the way I will go...I can not crawl under the dash anymore so will have the TCM pulled by my garage.guys and see if that helps...otherwise it's never driven in the rain type...
George05
Oct 23, 2021 02:05 PM
meeburtxk8
Nov 16, 2012 02:29 PM
barondess
Sep 14, 2012 09:36 PM
morethansamson
Jul 2, 2010 03:49 PM
