Code confirmation
Old Jan 12, 2011 | 08:04 PM
Kevin 03 xtype s's Avatar
Default Code confirmation
Codes
P 0335 crank sensor?
C 1125 left front wheel speed sensor ?
And are they going to cost 2 arms and a leg
Am I close? thanks
Old Jan 12, 2011 | 08:28 PM
sport30's Avatar
Banned
From Jag DTC summaries OBDII
P0335
EMSOBD II
CKP Sensor circuit malfunction
To monitor:
Start engine; momentarily
race the engine; stop engine
Repeat two additional times
Start engine; idle 30 seconds.
Accelerate from stop through
complete engine rpm range;
coast to a stop
Drive the vehicle steadily
between 48 – 97 km/h (30 –
60 mph) for 5 minutes; coast
to a stop
Accelerate smoothly through
complete accelerator pedal
travel; coast to a stop
Idle engine 30 seconds
Note: If CKP Sensor fault
exists and engine will not
start, battery voltage must
drop below 10.5 V during
cranking for DTC to be
flagged. (Crank period – 30
seconds.) If CKP Sensor fault
exists, engine will start on the
second crank as the ECM will
default to CMP signals for
synchronization.
2 A
Default action:
ECM Default:
– Maximum engine speed
reduced
CM pin number :
EN16
-036
-037
Possible Causes:
CKP Sensor disconnected
CKP Sensor gap incorrect / foreign matter on
sensor face
CKP Sensor sensing circuit:
open circuit, short circuit to ground,
short circuit to high voltage
CKP Sensor failure
Old Jan 12, 2011 | 08:30 PM
sport30's Avatar
Banned
C1125 is not listed in the Jag
Chassis DTC Summaries (Chasis "C" codes)
maybe a typo?
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
Terry H
Jul 4, 2017 05:48 PM
flyrr100
Sep 29, 2015 03:47 PM
ccfulton
Sep 20, 2015 05:15 PM
