Code Reader /Fault Diagnostics
Old Mar 27, 2012 | 12:04 PM
Lcgi's Avatar
Arrow Code Reader /Fault Diagnostics
Hello,
I was wondering if anyone can recommend to me a Brand or Model of Code Reader or Laptop & Software - to use on my 2004 2.5L X-type ?
I would like to to have a set-up that providse as much diagnostics as possible...
All help appreciated.....
Old Mar 28, 2012 | 02:30 AM
Thermo's Avatar
Veteran: Navy
Lcgi, your best bet will be to get one of the kits that you can plug into your USB port on a laptop and then using the supplied computer program, access a lot of the internal data. I had one at one time and while it was very useful, the one that I had seemed to need a lot of TLC to keep it going. Maybe the newer ones are more user friendly. I got mine back when OBD-II was still fairly new and no one knew a whole lot about them.
YOu can normally pick up one of the kits for around $150-200. If you try to get a hand held that will do the same thing, you are looking at $500+.
Old Mar 29, 2012 | 05:23 PM
disguay's Avatar
look at the elm327 code reader. It is a generic code reader that broadcasts in either usb or bluetooth. I personally have the bluetooth model and use it with my phone. It works amazing and it only cost $25 for the $5 app and the $20 code reader. I would highly recommend this if you are somewhat tech savvy and want a good, cheap reader.
Old Mar 30, 2012 | 08:54 AM
gottagetone's Avatar
Scangauge II
Old Mar 30, 2012 | 01:09 PM
Lcgi's Avatar
Hi fellas,
Thank you... you've have given me food for thought... and starting points.
Larry
philwarner
25
Jun 26, 2021 05:43 AM
ssshield
Sep 24, 2015 08:29 PM
John Fox
Sep 19, 2015 07:56 PM
jagfool
Sep 14, 2015 07:50 PM
bigmikeyt
Sep 14, 2015 12:06 PM
