Cold weather clutch problem
Old Nov 1, 2010 | 10:18 AM
Andy94SC's Avatar
Default Cold weather clutch problem
I noticed a problem last Winter with my X-Type (2004 2.5L Manual) where the clutch did not seem to be disengaging all the way. It was hard to get into gear from a stop, and clashed pretty bad changing gears.
I stopped driving it in the spring, when I got the XK8. I planned to get around to fixing it during the summer, but never got to it and honestly forgot about it.
But I started driving the X-Type again a month or two ago, and haven't had a problem until this morning. This morning was the coldest so far, 25 Deg F. when I left for work, and I again had the trouble getting into gear at a stop and clashing gears when shifting. So it seems that maybe the clutch has a problem completely disengaging when it is below freezing?
I am going to try bleeding the clutch (again) to see if that helps. Anyone seen something like this? I'm hoping it isn't something that requires me getting into pulling the trans to replace something in there...
Old Nov 1, 2010 | 11:03 AM
Tony_H's Avatar
Are you loosing brake fluid? If not, I'd guess the master cylinder. On my F150 (similar clutch) the problem was a leaking slave cylinder $$$$
Old Nov 1, 2010 | 11:32 AM
Andy94SC's Avatar
As far as I know no fluid leaks. The level hasn't dropped any that I can tell since I bled everything shortly after buying the car last fall.
Old Nov 8, 2010 | 07:18 PM
Andy94SC's Avatar
Well I bled the clutch again with one of those vacuum bleeders, and it seems better so far.
SD96XJ6L
Jan 12, 2022 04:30 AM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
joseph1945
Sep 5, 2015 07:12 PM
