Coolant leak
Old Nov 18, 2018 | 02:39 PM
Kyle Considine's Avatar
Default Coolant leak
Hi all,
I have an 03 xtype 2.5. Just replaced the thermostat and water outlet gaskets. 1 of the 3 bolts on thermostat stripped out. I also used liqued gasket maker on both parts. On the thermostat it is platic with metal rings inside where bolts go in as to not crack plastic. One of the metal bushings?? Tgat the bolts drive into sripped out and cannot get bolt tight. What is this bushing?? Called? And do i need to rethread the manifold bolt housing? Thanks any help is appreciated!
Old Nov 24, 2018 | 03:07 AM
x_type_lpg's Avatar
its a brass insert that was molded into the plastic housing when made. you could drill it out and use a nut and bolt, but better to just buy a new housing.
Harry Peter Rose
Feb 13, 2018 08:14 PM
Z07Brandon
Jun 22, 2017 11:48 PM
Nee_the_Bogeyman
May 8, 2016 07:25 AM
chtp66
May 26, 2014 06:45 AM
Nov 5, 2006 12:06 PM
