Coolant leaks
Old Oct 1, 2017 | 04:36 AM
Neil1983's Avatar
Default Coolant leaks
Hello. Does anybody have a diagram of the coolant system. I have a leak in a hose just below the starter motor. The hose finishes just above the oil filter. Can't find the name of the part to order. Thank you.
________________
2006 X-Type Estate 2.0 ltr diesel (added by GGG)
Old Oct 1, 2017 | 01:14 PM
Neil,
Here's the relevant extract from JEPC (Jaguar Electronic parts catalogue) for the X-Type (diesel) cooling system hoses:
If you can identify the hose, I can lookup the part number.
Old Oct 3, 2017 | 04:40 AM
Neil1983's Avatar
Smile Coolant leak
Thank you for sending the diagrams. I have taken the pipe off again. Can anybody identify it from the pictures?. It is only about a foot long with a twist in it. It comes starts just above the starter motor and finishes below. As you can tell I am a novice repair man
Neil
Old Oct 3, 2017 | 04:41 AM
Neil1983's Avatar
P.s. The third image...It connects to the small pipe almost in the middle of the image. Not the larger one in the bottom right section
Old Oct 3, 2017 | 05:08 AM
Neil1983's Avatar
Default coolant leak x type 2lt diesel 2006
Images
Attached Thumbnails Coolant leaks-img_2042.jpg   Coolant leaks-img_2043.jpg   Coolant leaks-img_2044.jpg   Coolant leaks-img_2045.jpg
Old Oct 3, 2017 | 03:04 PM
Dell Gailey's Avatar
I'm relatively sure it is the throttle body coolant hose
Neil1983
Oct 3, 2017 05:05 AM
Dale Dunn
Oct 19, 2016 08:40 AM
Ingo85
Oct 12, 2016 01:35 PM
XJR 308
Sep 30, 2016 10:08 PM
