Cooling system compacity
Old Apr 29, 2009 | 11:21 AM
morales8416's Avatar
Default Cooling system compacity
I am about to change out my antifreeze because of the leak on my thermostat housing seal. One question arises. How many liters of jaguar antifreeze i need to have correct 50/50 mixture. So if anyone can give me the answer greatly appreciated.
Juan
Miami. FL.
Old Apr 29, 2009 | 11:58 AM
Colt's Avatar
Banned
7.8 qts total
Old Apr 29, 2009 | 01:03 PM
the antifreeze comes in liter bottles. What i am asking how many liters i need to mix with the distilled water. for the complete system
Old Apr 29, 2009 | 01:08 PM
Thermo's Avatar
Veteran: Navy
Juan, the refill capacity of the system is 8.25 liters. So, if you buy 4 liters of coolant, you will be fine. The slight variation from a perfect 50/50 mix isn't that big of a deal. Worst case, you buy 5 liters of coolant and when you need to add any, you add in the straight coolant vice adding in water.
Old Apr 29, 2009 | 01:15 PM
thanks i apperciate it. exactly what i was looking for
Old Apr 29, 2009 | 05:04 PM
jimmy's Avatar
ud
if you are in an area that goes below freezing, i suggest a 60:40 mix not 50:50..
where did you get the 50:50 number? could not have been from the owners manual, because that has the capacity in it, and that was the question you were really asking.
Old Apr 29, 2009 | 05:46 PM
MarkC's Avatar
http://www.eetcorp.com/antifreeze/an...ze-faq.htm#q16
50/50 mix is good down to -34F.
Distilled water is way cheaper than antifreeze.
Why would you suggest 60/40?
Old Apr 29, 2009 | 05:52 PM
jimmy's Avatar
ud
From the back of the BMW coolant bottle.
normal use 50:50
extreme 60:40 for maximum protection.
trosty
26
Dec 18, 2022 06:40 PM
jdzubas
Oct 4, 2015 09:14 AM
willtoliv
Oct 2, 2015 12:18 PM
Jaguar_libra
US Western
Sep 9, 2015 04:20 PM
1100me
Sep 7, 2015 06:26 AM
