Cruise control not available
Old Feb 7, 2011 | 05:05 PM
Rob_W's Avatar
Unhappy Cruise control not available
Dear All,
First of all I would like to say Hello! to all Jag fans
I'm owner of X-Type '05 3.0 that I really love
Unfortunately recently something bad happend - when I was driving in dense fog I didn't saw on time quite deep hole in the road and I felt quite big shock. After that car was driving ok but "cruise control not available" warning appeared. After 40mins of driving I stopped and turned off the car. When I started to drive again after 20-30mins that message disappeared but cruise control stoped working. Currently engine and steering work absolutely fine but almost nothing happens when I press +/-/resume/cancel buttons - sometimes I only see "cruise control cancelled" after few seconds since I press + key.
Did anyone had similar behaviour?
Thank you in advance for help!
Rob
Old Feb 8, 2011 | 09:39 AM
sidewalkman's Avatar
Youi've got a vaccuum leak, search this forum, there are likely 50000 threads descibing the fix.
Old Feb 8, 2011 | 12:05 PM
Rob_W's Avatar
Vacum leak? My X drove only 25000 miles.
Wouldn't it cause performance degradation and other warning / error messages? My engine works perfectly - even when I try kickdowns everything's fine.
Old Feb 8, 2011 | 03:25 PM
nope not always. You still have a 6 year old car, open your hood, see if you can hear a hiss.
Old Feb 8, 2011 | 04:52 PM
Brutal's Avatar
Imt orings, pcv hose, brake booster pipe, replace them all
Old Feb 9, 2011 | 03:43 PM
Rob_W's Avatar
Today I checked sound of engine once again and I haven't heard anything
Cruise cancelled appears everytime I press press set + ...
Is there any cruise control sensor near breaking pedal? Maybe it causes some problems? What do you think about it?
Old Feb 9, 2011 | 04:37 PM
Brutal's Avatar
See my post above, forget noise, #1 issue with no cruise is a vacuum leak from the above offenders, and if thats turns out to not be it those should be changed anyway if original. And yes there are 2 brake switches, 1 for brake lights and 1 for cruise. But if youre not pulling codes and guessing youre going down an unlikely road first
Old Feb 10, 2011 | 03:29 PM
3JagMan's Avatar
I had same problem from my '02 2.5L. Turned out the intake O-rings were hardened. replaced them no more probs.
Old Feb 11, 2011 | 02:28 AM
Rob_W's Avatar
Physically they seem to be ok, but I have to connect my X to computer for detailed diagnostics. But it's really odd that it happend when my car bumped .... Thanks for help and advices!
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
leep123
Sep 30, 2015 03:41 PM
Camnelson324
Sep 27, 2015 08:48 AM
zdrapec
Sep 25, 2015 05:49 AM
