Crunching sound when going over bumps
Old Aug 11, 2010 | 10:53 PM
p3x935's Avatar
Default Crunching sound when going over bumps
Im a bit perplexed. I have a crunching sound coming from my front end when I go over bumps. I checked the obvious things like wheel bearings. The only thing I can see thats out of the ordinary is that the wheel well liners in the front end are loose. Has anyone run into this problem?
Old Aug 12, 2010 | 03:18 PM
BuckMR2's Avatar
Probably not the common drop links wear or ARB wear as these are more of a knocking sound over bumps so am guessing possible broken spring causing tyre to rub or perhaps shocker?
Old Aug 12, 2010 | 03:40 PM
Striker27's Avatar
I had a similar problem it turned out it was the control arm on the drivers side that caused the clunking crunching sound I was having. Hopefully your issue is fairly easy to find..
Old Aug 12, 2010 | 11:10 PM
p3x935's Avatar
Thanks for the suggestions.. will check it out this weekend and let ya'll know what i find.
GordoCatCar
Jan 2, 2017 01:10 PM
pk4144
Sep 24, 2015 08:29 PM
JagBrian
Sep 21, 2015 07:17 PM
ahunt4
Sep 19, 2015 09:49 AM
Martyn-R
Sep 8, 2015 03:56 PM
