a cutting out problem
Old May 16, 2012 | 05:37 PM
gasman's Avatar
Default a cutting out problem
Hi everyone. i am new to this forum so please bare with me as to how this runs, my 2005 2.0 diesel has started to cut out whilst driving. the glow plug light flashes on and off and the engine cuts, i can switsh the ignition off and it will restart straight away whilst still cruising. please does anyone have any ideas? I have changed the fuel filter. cheers all.
Old May 16, 2012 | 06:45 PM
Thermo's Avatar
Veteran: Navy
gasman, from the sounds of things, it is an ECU problem. The glowplug should only turn on when attempting to start the engine. The glow plug light coming on is telling me that the power is being cycled to the ECU. The question is what is cycling the power. You could have a wire that has gotten damaged and is now just barely making contact. now, when you hit a bump, that is enough to cause the wire to break, removing power to the ECU, then as the wiring settles back down, it can remake contact, causing the ECU to go through a start up cycle. This will also cause the injectors to not receive the proper signals to admit fuel to the engine, leading to the engine cutting off. This would also explain why the engine can be restarted and you are not getting any error codes (since the ECU is thinking you are shutting off the car).
99xk8guy
May 28, 2024 09:36 PM
Wolfy
May 28, 2024 08:06 AM
redrover41
23
Sep 25, 2015 01:33 PM
uncheel
Sep 5, 2015 01:34 PM
Jaguar Forums Editor
Jaguar Press release
Sep 5, 2015 10:08 AM
