Dash flicker
Old Oct 4, 2013 | 03:56 PM
Jaggy Jag's Avatar
Default Dash flicker
i upgraded my speakers in my 2004 jaguar x type, everthing worked fine, but lately my dash light flicker sometimes...also had hids kits done too...think I need a stronger battery?
Old Oct 4, 2013 | 07:38 PM
aCapiz's Avatar
When you mention flicker is it like a quick flickering of lights, or is it more like dimming that fluctuates with that the speakers are actually doing?
Old Oct 4, 2013 | 10:04 PM
Thermo's Avatar
Veteran: Navy
Jaggy, the dash lights flickering has nothing to do with your battery. Odds are, what has happened is at some point, something struck the headlight switch (specifically the small knob in the upper corner). That little knob is what does the dash lights that are flickering on you and if you damage it or it develops lots of internal corrosion on the rheostat, it will cause the lights to flicker like you are talking about. Sometimes you can turn the dial from min to max and back a few times and it will wipe the rheostat and cause the flickering to go away. But, ultimately, you are looking at a new headlight switch most likely barring a wiring issue. But, that will normally result in the fuse for the dash lights blowing due to a grounding issue.
Old Oct 5, 2013 | 08:41 AM
Jaggy Jag's Avatar
It's more like a quick off and on...it only happens sometimes...
Old Oct 5, 2013 | 11:41 AM
Thermo's Avatar
Veteran: Navy
Jaggy, I have the same flicker in my car.
Old Oct 6, 2013 | 08:24 AM
Jaggy Jag's Avatar
So I shouldn't worry much...?
Old Oct 6, 2013 | 06:46 PM
Thermo's Avatar
Veteran: Navy
Jaggy, unless it is bothering you at night with the lights doing what they are doing, I would not worry too much about it. As a side note, if you end up replacing the headlight switch, keep in mind that there are 4 different headlight switches based on whether you have the Canadian DRLs, American (no DRLs), Scandinavian DRLs, or the AUTO headlights. They all have little oddities to them and while they are somewhat interchangeable, before you do, let me know and I will let you know if what you are after is possible and if there are any modifications you may need to do.
Old Oct 7, 2013 | 07:17 AM
Jaggy Jag's Avatar
Thanks so much Thermo, I will let you know when I replace the switch...it's not to bad now...
goges
Oct 5, 2015 04:53 PM
Fletch44
Sep 28, 2015 02:21 PM
Long Islander
Sep 27, 2015 03:45 PM
the guardian
Sep 25, 2015 03:06 PM
