Dashboard help
Old Aug 10, 2011 | 10:56 PM
carlstev's Avatar
Arrow Dashboard help
Hi folks - first cry for help, or advice..
The dash clear cover over the tacho and clocks appears to have been over sprayed with some solvent which has 'etched' it (see below), anyone know of a product to clean or polish clear plastic back to.... clear plastic?
Old Aug 10, 2011 | 11:07 PM
QuintonChester's Avatar
Hmm you might go to like Advance Auto or Auto Zone and ask them if they have anything, they would definitely be able to provide you with the correct info. My first thoughts would be to drive into town and see what they can do for you. But if you really just wanna get something online, then you might go for something like this I would assume. http://www.amazon.com/Meguiars-G1231...cmu_pg__header
Curious as to how you got that out, cause I wanted to see if I could change the dash colors to like a blue :P Hmmmmm
Old Aug 11, 2011 | 12:12 PM
carlstev's Avatar
It's real simple to remove and I did take pictures/video.
Remove cover surrounding clocks with firm pull
Remove 4 crosshead screws to remove black cowl
Remove another 4 screws to clock assembly
Remove both electrical connectors at rear by firmly lifting/prying the plastic cam strap over the notch on the top of connector
All with power off and takes couple of minutes only
BTW: Mothers Plastic Polish appears to be the product with favorable reviews
Old Aug 11, 2011 | 01:45 PM
Thermo's Avatar
Veteran: Navy
CarlStev, I would first try to use a little bit of mineral spirits on a piece of paper towel. It would be preferable to have some automotive paint reducer (higher quality mineral spirits) as that will be a lot less likely to cause a problem with plastic (not that mineral spirits normally does).
After that, I would get some 1500 grit liquid polishing compound. Use that with a cotton cloth and that will clean up what you are seeing.
Old Aug 11, 2011 | 04:14 PM
xjrguy's Avatar
Personally, I wouldn't take a solvent to the plastic. I'd use something like this 3M Plastic Polish combo. I've had reasonable luck with it three or four times. Works well enough people keep stealing it from me at work.
Amazon.com: 3M Plastic Polish Combo with Plastic Cleaner and Plastic Polish: Automotive
Cheers,
Old Aug 11, 2011 | 04:53 PM
iownme's Avatar
how about using the kit used to clean hazy headlights?....turtle wax makes one for $8...worked great on my headlights....but practice it on a spare piece of plexiglass first
Old Aug 11, 2011 | 08:26 PM
Did you see any significant lights back there? Like would it be possible to change all the light colors? :P Just wondering, all feedback is MUCH appreciated! Sorry for threadjacking you.
Old Aug 11, 2011 | 08:35 PM
carlstev's Avatar
Thumbs up
appreciate the suggestions folks, thanks a bunch.
I went to my local Automotive Car and Truck Parts - Find Parts in Canada - PartSource: Automotive, Truck Parts & Accessories store to see the lineup on their shelves, all other Mothers products but no "Mothers Plastic Polish" (highly recommended in other forums)
Did see this though "PlastX" clear plastic cleaner and polish, see what you think of the results;
I'm pleased as punch
First image I have polished about half of the dash on the right, second image is complete
Attached Thumbnails Dashboard help-_dsc4924_resized.jpg   Dashboard help-_dsc4930_resized.jpg
Old Aug 11, 2011 | 08:45 PM
carlstev's Avatar
Sorry, wasn't looking but like I said only takes a couple of minutes to take apart with one 5" long cross head screwdriver (8 screws) and one 3/16" wide flat head screwdriver (to lever the electrical connector locking cam)
Old Aug 11, 2011 | 08:58 PM
iownme's Avatar
looks great...well done!
Old Aug 12, 2011 | 03:44 AM
Cadillac's Avatar
Awesome job, kudos to you
Old Aug 12, 2011 | 08:13 AM
pab's Avatar
pab
Whew, that was a close one...
Great job on find the right product and using it correctly!
Jaguar: Grace, Pace, and Space - Sir William Lyons
JaguarLover101
48
Jun 12, 2023 10:28 AM
carl purchase
Oct 14, 2015 06:14 PM
Steve10
Sep 20, 2015 12:27 PM
Saturbo
Sep 8, 2015 07:35 PM
