Dead battery?
Old Jun 22, 2011 | 11:26 PM
iownme's Avatar
Default Dead battery?
just got the car
when he arrived, the car would not restart after being shut down, he told me the battery was toast...he bought a portable jump starter with him, it started right up with the booster and drove fine with no "battery light" illuminated.
Sound like a dead battery?
Old Jun 23, 2011 | 03:03 AM
Cadillac's Avatar
Could be a battery test can prove that
Old Jun 23, 2011 | 07:13 AM
Thermo's Avatar
Veteran: Navy
iownme, odds are, yes, it is the battery. A quick check that I would tell you to do is to open the hood and connect a multimeter across the battery and position the multimeter where you can see it. With the key removed, you should be sitting at 12.6 VDC. If you are not, place the battery on a charger and see if you can get it up to 12.6 VDC. If it won't get there, battery is toast. Once at 12.6 VDC, attempt to start the car. Does the multimeter drop below 11.0 when cranking the engine. If yes, bad battery. Replace. If not, you are looking at a bad starter or a bad battery cable. Odds are, because the car starts with a jump, you would be looking at a bad cable. Fairly cheap to fix and not that difficult.
Hope this helps.
Old Jun 23, 2011 | 09:34 AM
iownme's Avatar
just picked up a battery from walmart...$105 versus advance auto $150.
gonna go put it in now
Old Jun 23, 2011 | 09:37 AM
iownme's Avatar
Hope this helps.
I'm at work in PA (live upstate NY) i only have basic tools with me, which does not include my multimeter....i figured toasted battery is most likely so i just bought a new one....besides, i like to put a new battery in a new car anyway
Old Jun 23, 2011 | 10:25 AM
iownme's Avatar
just replaced the battery and all is well, turned out the PO replaced the battery with a smaller one and had placed the battery on top of the vent tube, blocking off its venting capabilities, i'll bet thats what killed the battery
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
Rivguy
Nov 13, 2022 02:55 AM
ferraripete
Sep 12, 2016 09:02 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
