Denso Sat Nav Diagnostic codes
Old Oct 8, 2007 | 08:06 AM
jag_genius's Avatar
Default RE: Denso Sat Nav Diagnostic codes
you can't do anything thru the nav.. no drive away locking or global closing .. all that has to be done thru IDS.
Old Oct 8, 2007 | 05:36 PM
xdave's Avatar
(That link looks to be for the earlier system, not the later one which is also used in the X-Type.)
Code 1981 from your Ford link does work on the Jag system though (Edited: that might be 1971 after seeing the post below mine, I can't remember and don't have the car handy to check), and gives youa diagnostics screen for enabling and disabling options like the CD changer and phone. All changes to that will be lost when the car is restarted though. It is useful for running checks though if you have having any faults, and it will display the logged error codes.
To get to the PIN entry menu hold in Phone and Menu for five seconds.
Old Oct 8, 2007 | 05:40 PM
jag_genius's Avatar
just for the denso diagnostics.. is 917
Old Oct 22, 2012 | 11:36 AM
bazmo's Avatar
Default info
I have a file on sat nav code access I will try to attach it
File Type: docx
philwarner
25
Jun 26, 2021 05:43 AM
tsimms7
Sep 15, 2015 12:43 PM
texaspete
Sep 10, 2015 08:34 AM
Mike Green
Sep 7, 2015 12:39 AM
pegasus3710
Sep 5, 2015 09:40 AM
