diff oil leaking problem
Old Dec 30, 2008 | 12:43 AM
Gunz80's Avatar
Default diff oil leaking problem
few days ago, I went to oil change and mechanic notice me diff oil leaking.
so, he suggest me to change oil...he said old oil may cause this....
well....i had to go some trip...so....well I changed it...
but...I am still wondering that mechanic told me right thing?
and he said if it is not working I have to change the seal....
how much it cost??
Old Dec 30, 2008 | 04:49 AM
Mike S's Avatar
Default RE: diff oil leaking problem
If oil is leaking from your diff, then old or new a seal is worn... only slightly perhaps. I'm assuming that this is a drive shaft seal... which should be relatively easy to replace. I've never heard of 'old diff oil' being the cause of leaks. I'd consider a new mechanic or at least a second opinion. One thing I would be worried about is ... what has the mechanic filled the diff with? There are oils and there are oils. I don't know that the wrong diff oil will cause damage, but there could be issue. There was a recent post which listed all of the recommended oils for engines, transmissions diffs etc.
Mike
Old Dec 30, 2008 | 09:32 AM
htkenan's Avatar
I simply dont trust mechanics. I just changed my starter and I do my own oil changes. Also fixed my antifreeze hose that got loose and was causing my car to overheat. But, to this day I do my own repairs regardless.
Went to get my oil changed once, and they never changed it they just filled it up and thats it. Never got rid of the old oil.
I agree tho, get a second opinion.
Old Dec 30, 2008 | 10:31 AM
Gunz80's Avatar
ok...dirive shaft seal...is it really easy to replace? do you have any intruction? so that I will do it myself...
or should I take it to mechanic?
Old Dec 30, 2008 | 10:35 AM
Dennis's Avatar
ud
They are basically easy to change..(Differential Pinion shaft Seal)..you need to drop the rear U-joints and then need a impact wrench and a big deep socket to get the big center nut loose (that's the hard part) and then the shaft pulls out, there maybe a calibrated (torqued)crush nutto remove, then you snag the seal out..Better let a drivetrain shop around you do it..they have all the right tools.
Old Jan 3, 2009 | 01:25 PM
Gunz80's Avatar
yes, it is Differential Pinion shaft Seal leaking....
If it is not that hard to do it, I want to try to fix it.
Cuz I went to 'mr. transmission' they told me that it will cost $250...canadian..
well...i don't want to spend that much money, I already spended $2000 on tires and brake.
do you have instruction with pictures??
or recommanded mechanic around toronto???
Old Jan 3, 2009 | 08:08 PM
MarkC's Avatar
The JTIS instructions for replacing the pinion seal are pretty involved. It requires removal of the drive shaft, unbolt and lower rear diff, measure preload torque, etc. Pulling the input flange to access the seal also requires several special tools and all new fasteners. I wouldn't call this "easy".
You really should refer to JTIS for the details before you dive into this job. JTIS is available via download or EBAY.
Old Jan 3, 2009 | 09:30 PM
Gunz80's Avatar
hmm...sounds like it is hard job....
do you think $250 is reasonable price or should I look for other mechanic?
Old Jan 4, 2009 | 09:49 PM
Gunz80's Avatar
wow...it seems like really hardcore...
then,,,I should go to some special mechanic....
do you have any recommand mechanic in toronto ?
I only know 'mister transmission'....
kelliott
May 31, 2022 05:26 PM
jdzubas
Oct 4, 2015 09:14 AM
laserguy
Sep 3, 2015 02:02 PM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
