DIY Oil Pan Gasket and Rod Bearing Replacement write-up "How To"
Old Mar 12, 2017 | 02:42 PM
gkubrak's Avatar
Default DIY Oil Pan Gasket and Rod Bearing Replacement write-up "How To"
Well here it is, finally finished replacing all the rod bearings in my 3.0 Jaguar X-Type. I wrote up a nice procedure with everything you need for changing the bearings, oil pan gasket, as well as cleaning methods, tools and part numbers, as well as plenty of pics!
Total cost with parts and tools was about $225. Much cheaper alternative to replacing the entire engine. With the new bearings, I am proud to say the knocking noise has vanished!!
I must say this was the most involved repair I have attempted. Hopefully this gives other people the confidence to do the job themselves!
Thanks for all who posted in this thread:
https://www.jaguarforums.com/forum/x...ket-faq-11221/
It really helped me out when doing the job. Any feedback or comments are much appreciated !
A few notes: I ended up drilling a hole through the TC as well as removing the oil pickup tube from within the pan. Also, removing the front 3 spark plugs made it much easier to rotate the crankshaft for replacing the bearings. Check the cleaning and inspection section before finishing the job and replacing the oil pan.
See the PDF attachment below.
Old Mar 12, 2017 | 03:15 PM
Alfadude's Avatar
Wow! What a great write up. Thank you so much for taking the time to do that. I'm sure it will be a great help to anyone that.
Old Mar 12, 2017 | 03:31 PM
Definately one for the "How To" section.
Old Mar 12, 2017 | 04:34 PM
Lemons Racer's Avatar
That PDF is fantastic! I always thought it would be easier to replace the motor, but this may be a good option someday, hopefully far into the future lol.
Xerxes' Jag
Oct 26, 2016 05:16 AM
ghiadon
Oct 17, 2016 07:45 PM
Dennis Catone
Oct 5, 2016 06:43 PM
benpearce2013
Oct 2, 2016 08:06 AM
dubydogg
Dec 22, 2006 08:55 PM
