Do the dealer drain the transfer case during regular maintenance?
Old Nov 26, 2010 | 10:54 AM
Jaguarnewbie2011's Avatar
Default Do the dealer drain the transfer case during regular maintenance?
I have a 2002 Jaguar x-type 3.0 L with 121,000 miles. I get regular service done to it, and was wondering if the dealer refills the fluids on the transfer case during regular maintenance. I have done ALL of the service checks at a jag dealer? thanks!
Old Nov 26, 2010 | 11:08 AM
benebob's Avatar
ud
Nope and I would doubt they would. There is only a drain plug (no fill plug) so there is no way to check or top it off from factory. What you need is to install a oneway valve on the drain plug to pump in fluid. WildBill sells a kit, I bought it rather then trying to reinvent the wheel it works good but in reality if you're handy you can come up with the same set up at Home Depot for $50 or so.
Old Nov 26, 2010 | 04:40 PM
TheSeeker's Avatar
I would ask YOUR dealership that question. Mine claims that they do that and drain/refill the auto tranny at 100,000 miles. They also however claim that there's no need to do it any sooner than that (hello?).
Old Nov 26, 2010 | 07:34 PM
Brutal's Avatar
No, its not part of a regular scheduled maintenance schedule from Jaguar. (should be) I would do it and the drain and fill port are the same. You jack up the car about18-24" to the pinch mold from the ground (I don't remember but Ive posted it here before) and fill.
Its probobly in FAQ or sticky'd
Old Nov 26, 2010 | 08:44 PM
I honestly have no idea how to do any of these things. I will talk to my dealer and ask them what needs to be done, and if it can be done. They may not want to. What are the symptoms to look for when a transfer case is going out? -just for future reference
Old Nov 27, 2010 | 09:28 AM
Brutal's Avatar
noise from bad bearings with no or old bad burned lube
Old Nov 27, 2010 | 09:39 AM
I have had a bad bearing replaced before, so I know the sound it makes. Will the TC case typically just go out, or will the symptoms linger for a few days? I just want to know so that if it does start going bad, I will know and can trade it in and dump it off to avoid major repair.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
Rivguy
Dec 4, 2020 07:55 AM
Scarecrow
Mar 28, 2016 03:17 AM
Saturbo
Sep 8, 2015 07:35 PM
