Do I have to change the transmission fluid FILTER when changing oil?
Hello again,
After finally getting the new transmission oil cooler I called a mechanic to do the replacement and asked him to also change the transmission fluid. He asked me a question that I couldn't answer: ARE YOU ALSO GOING TO CHANGE THE FILTER? I believe that that would complicate the oil replacement with a complete removal of the tank. ... which would complicate with the removal of the seal gasket etc. Please tell me if my simple drain-and-fill solution doesn't require filter or other complicating replacements services. Thank you very much.
motorcarman (10-06-2022)
John in Tennessee
04-12-2022 04:03 PM
rsq911
03-12-2016 09:55 PM
