Door handle
Old Sep 11, 2008 | 06:55 PM
GarrinChilders's Avatar
Default RE: Door handle
I am having the same issue with my driver door, I was told awhile back that it operates slightly different than normal rod actuated door handles, as where (from what i was told, and this may 100% BS) it uses a cable instead of a rod that "is" adjustable at some point in the operation. by loosening an anchor point and pulling the cable taught in the system and re-tightening the nut, haven't had the time to fuss with as it seems worse in the summer mothes so it almost winter, and i am a pro at putting thing until later and door panel removal even with the how-to in the FAQ section scares me, theres so many little do-dads in the X, i don't want something to stop functioning. When i get the rest of my stereo upgrade ordered I will replace my door speakers and take a gander at the handle assembly while I'm in there.
I hope what I have told you is correct, I don't like giving false info, but no one else had chimed in so I thought I would at least try. :-) good luck and take pictures and post your finding for the rest of us.
Old Sep 11, 2008 | 07:52 PM
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
Size:  6.4 KBName:  T15ESSST101-1.jpg
Check this out.........may help a little
https://www.jaguarforums.com/m_32153/tm.htm
Good luck
Jim
Dz1rfj
Jul 17, 2018 10:29 AM
Col. Sandurz
Sep 28, 2015 12:49 PM
sadepol01
Sep 11, 2015 05:26 AM
1964Daimler
Sep 9, 2015 11:28 AM
hoodun
Sep 7, 2015 07:02 PM
