door projector lights/ puddle lights
Old 03-02-2016, 04:45 AM
mancjag's Avatar
Default door projector lights/ puddle lights
Hi ive just bought a set off door projector lights for my x type but realised my stock puddle lights are just reflectors. Any idea if theres any spare cables I could use ie power fold mirrors as mine aren't powered. Mine is a 2002 x type sport 2.1 v6.
Old 03-02-2016, 11:00 AM
mrplow58's Avatar
You will probably need to "T" off of the dome light console, and run the wires down the A pillars, to the place where the speaker wiring enters the door. Shouldn't take but a few hours, if you are careful. Be sure to tie the wiring out of the way of all the window components.....Good Luck......Mike
mancjag (03-02-2016)
Old 03-02-2016, 11:26 AM
mancjag's Avatar
Thanks for your reply Mike. I think I'll have to take your advice and run a cable to interior. Was wishful thinking that there would be a spare connection in the door that I could use. I was just hoping all the looms are the same and all optional extras might have wiring at the door connector just obviously no wiring from that to the puddle lights/ power mirrors etc.
Old 03-02-2016, 11:57 AM
wa3ra's Avatar
Make sure you check inside of the door first; I'd be suprised if the wire for the door light wasn't there.
Actually, rather than tapping off the dome light, simply tap off the courtesy light above the left-side footwell...which is where the factory tap is tied...on that side, and it's mate on the right for the right side door.
There is already a pass-through for wires between the wing and the door, you can run the wire in about a minute!
Old 03-02-2016, 12:09 PM
mancjag's Avatar
Thanks wa3ra Im going to take door cards off tomorrow so hopefully the wires are there. The rubber cable pass through between the doors are actually a plug and socket so can't actually get a cable through these ones unfortunately. Thats why Im really hoping the door looms are all the same and the wires will be there.
Old 03-03-2016, 07:35 PM
wa3ra's Avatar
If you don't have the wire for the door light run, the socket will have a position without a wire in it...carefully drill that out, and run the wire through that hole (both the wing and door side).
Reggie's Dad
26
08-19-2022 09:30 PM
shaz
02-05-2016 10:12 AM
Londo
02-04-2016 07:25 AM
mastereagle88
02-02-2016 01:17 PM
Dale Konkol
02-02-2016 10:28 AM
Quick Reply: door projector lights/ puddle lights
