doors not locking
Old Sep 24, 2014 | 08:52 AM
Her jag's Avatar
Default doors not locking
This is my first post. I (my wife) has a 2002 xtype 3.0 AWD.
Only the drivers door locks on drive away.
The fob only unlocks/locks the drivers door.
Sometimes (very rarely) the pass frt door will unlock the drivers door.
Any ideas?
Thank you in advance.
Old Sep 24, 2014 | 10:08 AM
Thermo's Avatar
Veteran: Navy
Her Jag, first off, welcome to the FOrums. Lots of good information here and lots of people willing to help. We do ask a small favor from you. We pride ourselves in being a better car group and as part of this, we like to keep things lively and getting to know one another. As part of this, please stop by the New Member Section and tell us a little bit about yourself and the car. This will also give you a chance to meet those that make this place what it is.
As for your problem. Based on what you are saying, it is sounding like the computer is not seeing the door lock state for your front passenger door. The computer actually locks the doors one at a time, not all at the same time like a lot of other cars do. So, when a door fails to lock, it stops the sequence on the door that is having issues and doesn't lock any additional doors. So, in your case, the computer starts with the driver's door then moves on to the front passenger door. It would then move on to the driver's rear door and ending with the rear passenger door.
So, odds are, you are looking at either the switch in the door for the lock is stuck or you have an electrical issue with the solenoid doing the passenger front door. If you stick the key in the driver's door and you roll it to the right, do all the doors lock? If so, then that would prove the wiring to the solenoid is good and therefore your problem lies in the lock position switch. If the door doesn't lock, then most likely you are looking at a bad door lock solenoid or its associated wiring.
Old Sep 26, 2014 | 09:02 AM
Her jag's Avatar
THANK YOU for the info.
Key in drivers door only unlocks/locks that door.
I will remove the pass panel to verify cond. of componets.
Thanx again.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
mrsimpson
Sep 15, 2015 01:10 PM
