drivers electric window
Old May 13, 2018 | 07:17 AM
greenestate's Avatar
Default drivers electric window
Got in my X type this morning ... flicked the switch and the window went down nice and quiet.... got to work .. flicked switch again to close window which it did sort off ...but with lots of crunching and a loud bang.
I'm assuming this is the window regulator at fault ....I dont want to open the window again until I've got a possible fix ready.. Does any one know of a vid or pictures of how the regulators come out.
Is this part that is 'shared' with a Mondeo or are they different...be nice if they were as mondy regulators are cheap as chips brand new.
thanks for any help .
Old May 13, 2018 | 11:38 AM
new mexico's Avatar
It might help to keep those felt channels lubricated with ARMOUR ALL.
Walter
Old May 13, 2018 | 01:35 PM
dwclapp's Avatar
greenestate: I don't know if X-Types and Mondeo's use the same window regulators, but for X-Type's they're not difficult to find at recyclers. Search part number C2S45944 (same part in Saloons and Estates). Here's a UK recycler for 27 GBP (37 USD):
https://www.ebay.com/itm/WINDOW-REGU...i:263419614053
Old May 13, 2018 | 02:50 PM
dwclapp's Avatar
greenestate: A trick to replace a window regulator........
Raise the window mostly to the top so you can access the old regulator. Clamp two short pieces of wood inside the window with the bottom of the wood resting on the window ledge inside the door. The wood supports the window so it won't fall after you remove the old regulator, and makes it easy to install the new regulator.
I can't take credit for this trick as it, along with the attached picture, are from a Toyota Sienna forum.
Attached Thumbnails drivers electric window-toyota-sienna-window-regulator-repair.jpg
Old May 13, 2018 | 04:17 PM
Dell Gailey's Avatar
It would be interesting if a member removed one of these and then compared them to the modeo in UK and or the Ford Focus in the U.S. Looking at the pictures of them all on sites, they're not clear and detailed enough to see if they will work for Jag X's.
Old May 14, 2018 | 03:01 AM
Thanks guys... I'll be using the wood and clamps trick for sure .
I found a regulator in a breakers for £18 in the end and have ordered a repair kit £7 for the one that comes out ...so I can hopefully have a spare if the existing one is repairable.
Hopefully I'll tackle the job Wednesday as I've got pre-op appointment tomorrow for my hernia operation.
Old May 15, 2018 | 01:29 PM
wa3ra's Avatar
That "bang" is most likely the plastic window support, which I'll bet it the 7-quid kit part.
That was all I had to replace in mine.
Old Jan 9, 2021 | 10:56 PM
Ftyperegistry's Avatar
wrong post.
POD XF
Jul 11, 2020 12:02 PM
martek
Sep 13, 2018 06:02 PM
02silver_x-type
Dec 22, 2014 07:45 PM
Red Mist
Nov 13, 2008 05:38 PM
