Drivers side CV axle shaft seal possibly leaking
Old Jul 20, 2018 | 03:30 AM
Spikepaga's Avatar
Default Drivers side CV axle shaft seal possibly leaking
Hello all-
i had to have the entire drivers side axle shaft removed because I was having a wheel bearing fixed and things where impossible to separate in the normal way.
When the shop removed the axle lots of transmission fluid came out which we collected, measured and replaced at the end. I asked the shop (which specializes in axles only) if I needed a seal so I could get one delivered or purchased at the dealership, they insisted no seal was needed. We went back and forth until they convinced me the seal would be fine.
Now I think transmission fluid is leaking, possibly when the car is driving, as I had the car up for unrelated reasons (tires) and I saw a drop of fluid near the area. I ran my finger right thru the actual area where the shaft meets the axle and that seemed dry. Shop thinks it’s just fluid from yesterday when they took the axle out.
I regret not sticking to my gut feeling to change that seal.
Can anyone one give me advise on what to do here? I have cleaned the area as best as I could, but if it’s leaking while driving I would not know since the drops are probably getting burned of if it’s just weeping.
Has anyone change the drivers side axle without changing the shaft seal? Looks like the seal is a 20 dollar part C2S12111.
Old Jul 20, 2018 | 03:29 PM
Dell Gailey's Avatar
By axle shaft, do you mean the CV shaft. If so, yes the internal seal can be damaged if they pulled the shaft out too far.
Read here =
https://www.jaguarforums.com/forum/x...acement-76071/
Old Jul 20, 2018 | 03:35 PM
Oh and btw, note that it leaks transmission fluid INTO YOUR TRANSFER CASE. Lovely, that.
Old Jul 20, 2018 | 03:48 PM
Spikepaga's Avatar
No, that’s the right passenger side US, thank God I know that much after owning two of these cars....This is the drivers side one which can be removed like a normal car, but it’s the shaft seal that may be leaking
Old Jul 21, 2018 | 01:33 AM
I could only find one post (02/13) for left side. In replacing it, they boogered the (dealer $21) seal, so might be.
Old Jul 21, 2018 | 09:12 AM
Spikepaga's Avatar
Thanks I saw that one too. Reading that post it seems that they knew they ruined the seal on the way out. In my case, they inspected the seal and where sure it was not going to leak based on their experience.....
Old Jul 22, 2018 | 08:45 AM
Spikepaga's Avatar
I have been checking on the seal getting under the car and the area seems dry.
Can anyone comment on having the seal changed or not? .... I am not sure it is common SOP to change the seal out when removing the left axle of not.
Old Jan 5, 2023 | 06:18 PM
John B's Avatar
Default Driver side CV axle seal
Yes the C2S12111 seal is the correct driver side (left side) one. I just installed it in my 2007 petrol x-type.
doriel
Feb 1, 2022 01:58 AM
orangeblossom
Jul 19, 2018 04:15 PM
innzane
Oct 24, 2017 04:04 PM
Bkny85
Feb 4, 2014 12:54 PM
penguin
Mar 18, 2013 12:10 PM
