DSC System Error
Old Oct 13, 2010 | 09:30 AM
slenser's Avatar
Default DSC System Error
What started out as a periodic problem has turned into a constant error in my 05 X. I thought it was due to a low battery (it started after being in storage and not run for several months), but I don't have any issues with the battery or charging, so it would seem unlikely. Everything seems to run just fine besides the error light and display. If you guys have any helpful insight into this, I would appreciate it.
Thanks,
Sam
Old Oct 13, 2010 | 01:29 PM
Jaguardoc504's Avatar
It's the battery, had the same issue in my 05'.
Dealer told me to replace the battery, as this was a TSB out by Jag at the time.
Refused to pay the dealer price for an re-labeled Interstate battery.
And they refused to diagnose the car any further until i replaced the batter.
Replace battery, with a yellow top, and the problem went away.
i had no starting issues, no charging issues.
Old Oct 13, 2010 | 06:33 PM
SEBZX79's Avatar
Thanks,
Sam
I have a DSC Fault light along with ABS light. When we read the error code it showed us comunication error with both front and rear left. I checked the sensor on the front everything looked good. This is on a 07 xtype.
Old Oct 14, 2010 | 05:13 AM
slenser's Avatar
Thanks guys, I think I'll try hooking a code scanner from one of the parts stores to see if any codes pop up and have the battery tested at the same time. Even if the battery does test good, I may replace it anyway as suggested.
Old Oct 14, 2010 | 03:59 PM
slenser's Avatar
I had the battery checked and it is bad. I'll try filling up the cells with distilled water before replacing it. Hopefully that is all it needs...they are each a little low.
Old Oct 14, 2010 | 04:09 PM
Jagtec1's Avatar
If it is the original, it need a NEW battery.
Old Oct 14, 2010 | 04:11 PM
sidewalkman's Avatar
Won't make a difference, bite the bullit and get a new battery, mine wouldn't hold a charge, added distilled water, held the charge (or so it seemed), then the battery light started flickering and I made it home but every fault light was on.
Replaced the battery cleared the codes and everything was perfect. it was 60.00 so......
cissdm
May 3, 2016 06:02 AM
scooternva
19
Oct 27, 2015 02:14 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
tonyforman
Sep 10, 2015 07:23 PM
