DSC warning, how much to fix
Old Feb 3, 2011 | 05:44 PM
MosDefXType's Avatar
Default DSC warning, how much to fix
guys I am about to purchase a x-type for $5500, 02 2.5l and 83000m. it has a warning light, DSC. it drives well. how much to fix and would you recommend I by this stylish car.............I really want a jag, the x-type.
Old Feb 3, 2011 | 05:55 PM
jaglover922's Avatar
Default DSC light.
you have to figure out what code is being stored in the abs/dsc module, then we can give you more insight.
Old Feb 3, 2011 | 06:54 PM
RobGardnerBlack's Avatar
Originally Posted by jaglover922
what code is being stored in the abs/dsc module.
I recently had to replace DSC Module, cost a shed load. Make sure you get to the bottom of it before comitting to car.
Old Feb 3, 2011 | 07:00 PM
well its buy as it is, i cant get the codes before i buy the car
Old Feb 3, 2011 | 07:17 PM
Good leverage to get the price down further, possibly?
Old Feb 3, 2011 | 07:50 PM
how much did you pay for the replacement?
Old Feb 3, 2011 | 09:52 PM
Vettklr's Avatar
Old Feb 4, 2011 | 06:17 AM
Thermo's Avatar
Veteran: Navy
Mos, figure this into the price of the car when thinking about whether it will be a good deal or not. First off, plan on spending another $100 to have a dealership or professional shop hook up their computer to get you the code out of the car (can't be obtained from your local auto parts store code readers). It may be something cheap and easy like an ABS sensor (around $100 for a new one as I recall) and installation is really easy (basic hand tools, a 10 year old could replace it). Then you have a wiring issue for something like this. Could be a damaged wire right out near one of the speed sensors, it could be something under the dash. You never know. This repair could be fairly cheap to fix, could be fairly expensive ($500+). Then you have the computer module. A used module from a junkyard will probably set you back about $300 plus installation/programming, a new module will be up around $1000 plus installation/programming.
So, are you willing to drop up to around $7000 possibly on this car? that is only a call that you can make. Just pointing out things to consider. You could get a hell of a deal and get the car for down around $5600, but there is the other side.
Old Feb 4, 2011 | 10:29 AM
ghettomike's Avatar
+1
Old Feb 4, 2011 | 10:49 AM
thanks guys, i walked i away. did some research and i think it was going to be too expensive at the end of the day. the search goes on. soon i will be driving a x type.
Old Feb 4, 2011 | 10:51 AM
Parties over, but for reference it was $1,500 as the dealer was required for programming
Old Feb 4, 2011 | 05:07 PM
got another one, 03 3.0 98000m. $5200. will check it out on sunday.
Old Feb 5, 2011 | 03:17 PM
Pacobell's Avatar
The DSC warning came on two times in the four years I have had my 2007 Jag Wag. Both times the cause was the battery getting low. Check the battery charge to be sure that's not the problem. Batteries don't last more than 2 years or so down here in FL. Good luck
Old Feb 6, 2011 | 09:43 AM
C5pilot's Avatar
My 05 DSC warning was also caused by a weak battery. Started giving me a warning on the coldest days but a restart would clear the message. Then it started happening during warmer weather and eventually on every start. Jagtech1 suggested it could simply be a weak battery and he was absolutely correct. Apparently the computer is very picky about getting the exact amount of current. As the battery gets weak, starting the car causes enough drain that some systems malfunction. The entire scenario progressed slowly over a 1 year period yet the car NEVER had any trouble starting, even in 0*F temps. It appears the original battery lasted about 6 years, not too bad.
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
RoyLittle0
May 25, 2023 02:38 AM
Jpav27
Jul 31, 2022 06:43 AM
jaguarbill
Sep 5, 2015 11:43 AM
