Dual fan assy 04 X-Type
Old Oct 6, 2008 | 09:16 AM
laurielalone's Avatar
Default Dual fan assy 04 X-Type
Notice a slight squeel from fan area after engaging A/C. Shop diagnosed A/C fan motor as the cause of squeel. Because this is a dual fan and shroud assy, I'm looking at $375.00 from dealer. Does anyone know if the fan motor can be rebuilt, replace separately, or a supply house that sells these thing cheaper? Thanks in advance for any help...new to Jags
Old Oct 6, 2008 | 09:21 AM
racerx82's Avatar
Default RE: Dual fan assy 04 X-Type
Some can be rebuilt but you're not likely to find the right brushes. I would pull fan shroud and soak with motors with Wd-40. If you have the know how, i would pull electric motor out and add some grease to bearings as well.
If you can't do any of it....looks like you're out of luck. If you pay the mechanic to do it, your best bet is to have it replaced then (labor cost will probably exceed cost of new fan)
good luck
Old Oct 6, 2008 | 09:28 AM
thanks..I was afraid of that. just got call from shop. Jag has come out w/new style that requires new wire harness..now to the tune of $500
Old Oct 6, 2008 | 09:48 AM
racerx82's Avatar
This from a dealer? i don't recalling them doing this...
Old Oct 6, 2008 | 09:58 AM
yes..Alpine Jag Ft Lauderdale, FL. cannot replace w/o new harness
Old Oct 6, 2008 | 10:00 AM
racerx82's Avatar
Hmmm...they must be using a different fan assembly that doesn't match the factory wires. All good i suppose if the dealer is involved. Too bad the price went up...should be covered under some sort of recall or warranty since it seems to be a factory fault in wires....
Good luck!
Old Oct 6, 2008 | 10:14 AM
I questioned them on recall...no recalls on this. I have an extended warranty from service shield. A/C fan motor covered if in connection of another MAJOR A/C component failure, Which make no sense to me. It would cost the company more if fan failed and cause problems to other components. Thanks for the input!
Old Oct 6, 2008 | 03:26 PM
Joe_04_XJ8's Avatar
Here is an aftermarket fan assembly that will fit an 04 X-Type on ebay.
http://cgi.ebay.com/ebaymotors/Parts-Accessories_Car-Truck-Parts-Accessories__FAN-SHROUD-jaguar-X-TYPE-02-05-04-03-2002-2005-2004-CAR_W0QQitemZ370089420040QQddnZPartsQ20Q26Q20Acces soriesQQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20Acce ssoriesQQddiZ2811QQadiZ2865QQcmdZViewItem?hash=ite m370089420040&_trkparms=72%3A543|39%3A1|65%3A1 2|240%3A1318&_trksid=p4506.c0.m245
Old Oct 6, 2008 | 05:45 PM
racerx82's Avatar
Way to save the day! Wonder if she'll get t in time
Old Oct 7, 2008 | 01:23 AM
Joe_04_XJ8's Avatar
Thanks Racer, I sure hope so.
Old Oct 7, 2008 | 09:56 AM
Joe_04_XJ8's Avatar
This one is a Jaguar fan assembly taken from a salvage car.
http://cgi.ebay.com/ebaymotors/ws/eB...m=120313023449
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
vwbusbits
Oct 13, 2015 03:43 AM
vwbusbits
Oct 1, 2015 01:17 AM
