Early Trunk Latch Replacement
Old Feb 17, 2020 | 10:26 PM
95naSTA's Avatar
Default Early Trunk Latch Replacement
I found out the hard way that there was a TSB to replace the early faulty trunk latches. The new part came, didn't fit and when I went to return it, found the TSB. I only found one picture and info stating that early cars have the 2 bolt faulty latch, then jaguar started provisioning the trunk lit with both a 2 and 3 bolt pattern to accommodate a revised 3 bolt latch but the 3 bolt latch wasn't phased in immediately. Fitting the revised latch on early cars requires drilling 3 new holes. To me this is a little ridiculous but it beats putting a used faulty latch back on the car.
For anyone with an early car and only a 2 bolt pattern here are some additional pictures and info to guide you through.
You'll need the latch, p/n C2S46309 and either an additional torx bolt or short 10mm (head) bolt. Loctite is a good idea too.
All I did was trace the new latch onto a section of paper, cut that out, line it up with the latch bracket, center punch the 3 new hole locations and drill.
Old left vs. new right.
javigo1971
Sep 30, 2019 04:58 AM
altonleehester
Jun 20, 2019 10:10 PM
meirion1
Jan 4, 2019 04:04 PM
intucker
Aug 4, 2011 09:25 AM
sacrider
Feb 5, 2010 07:34 AM
